How many teeth??
Old Mar 12, 2012 | 11:47 PM
cacasal's Avatar
cacasal
6th Gear
Question How many teeth??
I have a1998 Dyna Low Rider and I'm considering changing my rear drive pulley to a 65 tooth down from the stock 70. My stock belt has 133 teeth, what size belt would I need for the new pulley?
Thanks folks
Old Mar 13, 2012 | 12:51 AM
hboat's Avatar
hboat
Here is some info from the Andrews website. They make replacement pulleys for the primary side (forward side) of the final drive. Perhaps from this info, you can interpolate, approximate, and/or guess what 5 teeth added to the rear sprocket might do. Lots depends on how much/little room you have on the existing asle adjustment.
This doesn't answer your question, but it's something to think about.
Good luck.
PS. I'm also wondering why you want to gear your bike up, rather than down???
Old Mar 13, 2012 | 06:51 AM
8541hog's Avatar
8541hog
In order to have any adjustment left on your rear axle, I would think you will need a belt 2 teeth shorter. For each tooth change on a rear you gain/lose approx 1/8" of adjustment on the axle.
Since you have to replace the belt, I would change the front sprocket instead. each tooth on the front equals roughly 2 teeth on the rear when changing. You can change 2 teeth on a front without changing the belt. Either way you are opening the inner primary.
Old Mar 13, 2012 | 06:52 AM
SteveO-ll's Avatar
SteveO-ll
I might be interested in your 70 Tooth/Gog rear pulley, mine's a 68 tooth so that would give me a little better bottom end.
PM me if your interested in unloading the one your changing out.
Old Mar 13, 2012 | 07:43 AM
nathanw's Avatar
nathanw
Five teeth seems like a pretty big jump, are you sure you want to go that far?
Old Mar 13, 2012 | 07:45 AM
8541hog's Avatar
8541hog
Less than 10% change, or roughly equivalent to a 2 tooth change on front, not that big of a difference
Old Mar 14, 2012 | 12:59 AM
cacasal's Avatar
cacasal
6th Gear
Good luck.
I'm not adding 5 teeth....I'm reducing the rear sprocket from 70 to 65.....Which was the stock set up for export bikes....except to Australia which I recall as being 61 teeth...
Old Mar 14, 2012 | 12:18 PM
jpace024's Avatar
jpace024
So you want more top end? or lower revs at cruising speed? Most go the opposite way (more teeth on rear pulley, less on front) for more acceleration.
deadhawg
Aug 20, 2023 07:07 PM
rgr357
Oct 29, 2014 03:28 PM
hoggy05
Apr 12, 2013 10:17 PM
superstandardFL
Apr 3, 2013 02:26 PM
rmarion
Mar 8, 2007 05:13 PM
