bad leek
Old Jan 6, 2007 | 09:12 PM
riderj's Avatar
riderj
3rd Gear
Default bad leek
how do i stop the leek on primary case.i have put new gaskets silocone.but does not stop.any help would be great
Old Jan 6, 2007 | 09:21 PM
glebo's Avatar
glebo
Default RE: bad leek
where at?? gotta pic? that would help. What did you do/replace, info would be good to help troubleshoot.
Old Jan 6, 2007 | 09:59 PM
waterman7474's Avatar
waterman7474
YIKES!!!! those little onions can be real bastards if you get one with an attitude problem!!!!
JK
you mean LEAK.
sorry, i couldn't resist.
Old Jan 6, 2007 | 10:11 PM
but Ill try 2 try's Avatar
but Ill try 2 try
I guess you're not talking about your derby cover cause a gasket and silicone should do the trick. As glebo said, did you change out parts, torque something on unevenly, add a new part that's machined wrong?
Old Jan 6, 2007 | 11:03 PM
riderj's Avatar
riderj
3rd Gear
i cleaned all surfaces.a new gasket ansd silocone on both sides of it.and it still leaks in 3 places 1 on top and the others on bottom the primary chain cover is a drag specialties. no pics right now
Old Jan 6, 2007 | 11:05 PM
riderj's Avatar
riderj
3rd Gear
Old Jan 8, 2007 | 07:33 AM
rh8234's Avatar
rh8234
Did you torque all the screws in the proper order? You need to tighten them in the sequence specified in the manual. If so, check the primary cover for warpage. Place it on a flat surface like a saw table and make sure it is flat.
dproto09
Jan 19, 2017 10:07 AM
Deerslayer011
Jun 26, 2016 08:48 AM
emperor wurm
Nov 15, 2011 04:10 PM
qwispichkn
Nov 16, 2008 05:33 AM
monsterdeluxe
Nov 15, 2007 12:59 PM
