Rinehearts on a wide glide?
Old Jun 12, 2012 | 02:49 PM
AllenW's Avatar
AllenW
Default Rinehearts on a wide glide?
Can't find a bike to compare with, but has anybody put the Rineheart 2 into 1 exhaust on a 2012 or ? wide glide and did the ground clearance improve?
tia
Al
Old Jun 12, 2012 | 05:24 PM
maddghost's Avatar
maddghost
If they haven't changed the frame on the '12's it would fit just like on an '08. I have never scraped my bubs (which is the same as a reinhart pipe) , it's always my heel then the peg that scrapes.
Old Jun 12, 2012 | 06:47 PM
AllenW's Avatar
AllenW
Thanks much, with the wife on we tend to scrape the stock pipe from time to time.
Least we did till I went with HD 13" progressive shocks, but would like to go to just the standard spring rate as it's a bit to stiff with the HD springs.
That probably will let the bike sit a bit lower with both us on.
Al
Old Jun 13, 2012 | 09:43 AM
NoMax's Avatar
NoMax
on my 2012 WG i scraped the stock exhaust quite a bit when 2-up. i put the Rineheart 2 into 1 on and haven't scraped it a single time, definitely improved the ground clearance. i made no other changes to shocks or suspension.
Old Jun 13, 2012 | 11:12 AM
AllenW's Avatar
AllenW
Great to hear NoMax, I like the pipes and they're suppose to give fairly good performance (adding big sucker A/C, S&S cams and TTS Mastertune) and still be quiet enough when needed to keep the neighbors happy.
Al
Old Jun 13, 2012 | 12:12 PM
SuperglideKen's Avatar
SuperglideKen
I love the sound of those Rineharts!
Old Jun 13, 2012 | 12:38 PM
ynots's Avatar
ynots
unless your packing some serious weight the HD progressive shocks are known to be rough riders. With the standard rate springs and 2into1 exhaust you should be fine. Like maddghost mentioned the bub 7's aside from the end caps are identical to the rineharts. Might save you a few bucks, there made by Bub Reinhart
Old Jun 13, 2012 | 02:45 PM
AllenW's Avatar
AllenW
Ya, while I have a few extra pounds and the wife isn't as thin as she used to be, we must fall short of what the HD springs need, like riding an old hardtail it seems..
I am sending them back to have the standard springs installed, that should work out better, shocks are a inch longer and with the standard springs it should work, I hope.
Seems we're between stock shocks and the HD versions.
I might have a discount going for the Rinehearts, but if that falls through I'll look at the Bubs, thanks.
Al
Old Jun 13, 2012 | 02:51 PM
jb7's Avatar
jb7
I have a Rinehart 2-1 on a 2012 Superglide, haven't scraped the pipe yet with the stock shocks, used to scrape the stock exhaust all of the time.
Old Jun 13, 2012 | 03:45 PM
AllenW's Avatar
AllenW
Thanks guys.
Al
