Question on gearing
Old Jun 14, 2012 | 08:10 AM
JohnC FXDX's Avatar
JohnC FXDX
Default Question on gearing
I've see a lot of threads on changing the gearing from 3.15 to lower. I also heard that some earlier models used the lower gearing. I only thought it was the touring models though. I did find a couple posts that mentioned what rpms at mph with stock vs. 3.37 gears. I have a dial tach so its hard to read the exact rpm, but I am at 3100-3200 rpms at 70 mph in 5th. According to what I read, stock is somewhere around 2,900 and lower gearing is 3,150. Is this correct for my year Dyna though?
Old Jun 14, 2012 | 06:11 PM
JohnC FXDX's Avatar
JohnC FXDX
No one on this one?
Old Jun 14, 2012 | 06:33 PM
PoCoBob's Avatar
PoCoBob
Not sure if this helps or not, do a search here for changing the front drive sprocket. Way easier than cracking open the tranny and changing gears. I think most posts from people who have done it go to a 30 tooth front sprocket. I think the stock one is 32 but I may be wrong on the numbers.
Old Jun 14, 2012 | 07:05 PM
JohnC FXDX's Avatar
JohnC FXDX
That is where I saw the info about the rpms. I'm not talking about internal gearing. I'm talking about the compensator and clutch basket gearing or the front belt sprocket. I belive the rpms change when you change the compensator gears. I'm just trying to verify if the earlier Dynas or FXDX models had the lower gearing. I'm not ready to pull off my primary cover to look.
Old Jun 15, 2012 | 07:17 AM
8541hog's Avatar
8541hog
If you are running 3200 RPM at 70 in 5th, it sounds like you have a 30T already.
I have a 31T and run right at 3000 at 70 in 5th. This is with a 70T rear sprocket/pulley
Old Jun 15, 2012 | 07:21 AM
JohnC FXDX's Avatar
JohnC FXDX
Thanks hog. I thought so. 1st gear is quick unless I'm getting on it all the way.
Old Jun 15, 2012 | 07:27 AM
8541hog's Avatar
8541hog
Here is what I found on gearing comparing yours to mine:
2001 FXDX
32/70-tooth sprockets; 2.188:1
Gear Ratio:
1st 10.110
2nd 6.958
3rd 4.953
4th 3.862
5th 3.15
2005 FXDWGI
Gear Ratio (overall)
1st 10.110
2nd 6.958
3rd 4.953
4th 3.862
5th 3.150
So I would say you have a 30T for sure if the RPM's are at 3200 @ 70 MPH in 5th.
Old Jun 15, 2012 | 08:56 AM
JohnC FXDX's Avatar
JohnC FXDX
I read a sticky on another forum about the primary gearing. It says that there was two different gearing offered from '99-'01, but it only mentions the touring bikes. It states that the early EFI bikes had 3.37 gearing vs. the 3.15 of the carb bikes. The primary gearing was 25t/36t for 3.15 vs. 24t/37t for the 3.37 gearing. It doesn't mention the Dynas though. I know the FXDX was supposed to be the sport model, so I was wondering if it too used the lower gearing stock. This would make the difference that I see. If not, than one of the two previous owners must have changed either the primary gearing or the 30t belt pulley.
Old Jun 15, 2012 | 09:06 AM
8541hog's Avatar
8541hog
I could only find the one set of gear ratios for 2001 and they are the same in 2005, I don't they changed Dyna gears until the 6 speed came out.
88lowrider
Nov 2, 2014 11:39 AM
JohnC FXDX
May 28, 2013 11:43 PM
C.H.L.
Mar 6, 2013 07:06 PM
berndog
Shovelhead
Apr 21, 2012 10:17 AM
Tltrump
Exhaust System Topics
Nov 28, 2007 08:06 AM
