FXD with Wide Glide conversion?
Old Jan 11, 2007 | 11:45 AM
JSW's Avatar
JSW
Default FXD with Wide Glide conversion?
Anyone out there have any experience with this conversion, on your own bike or otherwise. I've been itching to do this on my 2002 FXD (did a search and found only one thread on this topic). I would love to know if its a move that is worth the cash. I think I could handle it myself, and would love to hear some experiences first.
Old Jan 11, 2007 | 12:26 PM
Naz_Man's Avatar
Naz_Man
Default RE: FXD with Wide Glide conversion?
I got the wide glide conversion kit fromaccutronix, it's the gothic kit.
Old Jan 11, 2007 | 12:30 PM
nine11c2's Avatar
nine11c2
Check out this months American Iron. I think they put a raked fork on a Sporty without changing the neck rake. The kit looked good and would assume one available for Dyna.
Old Jan 11, 2007 | 01:14 PM
glide05's Avatar
glide05
ORIGINAL: JSW
JSW,
I'll answer the 2nd part first - you can certainly do this yourself. You will need some quality tools, especially a high quality torx (I think t-45) to take the pinch bolts out of the original setup. You will need a decent bike lift. You will also need to get a new lower head bearing and dust shield from the dealer, the old one just will not come off, so be prepared for that (although it might be included in some kits). You can probably do this all youself though another pair of hands makes it much easier and less risk of dropping something expensive.
Now - is it worth it? Only you can decide that. You can spend around $700-800 for a kit that includes new trees, axle and t-shaft and hopefully a spacer for the disk. Going this route you will reuse your forks.
Another option is to spend thousands on a kit that replaces the exising forks as well, typically with something a bit meatier than the 39mm. Now you have to worry about spacers, fender brackets, etc. which are not likely included.
I've read that most who do this prefer the mid glide look if using the existing forks, they think the 39mm forks look too thin in the wide setup. I'm not sure I agree after looking at naz_mans setup, looks pretty good to me (personally not sure I'd go with the goth, but that's just me, the dimensions look fine, and his setup looks really nice, and very personal - probably never see another one just like that!).
Also - keep in mind that once you do this - other changes follow: As shown in naz_mans setup, you will need to replace the headlamp, and once everything else up front is nice and shiney, you'll want to get a chrome speedo bracket ... then you'll want to change the bars........ then you'll need new cables ........ then .... then .....
Dealing with the speedo and idiot light wiring is going to be a hassle. Once you change the headlamp, there is a lot of wiring exposed that needs covering somehow.
Maybe naz_man can comment on how the change to wide affected the bikes handling??
Old Jan 11, 2007 | 02:26 PM
JSW's Avatar
JSW
Thanks for all the replies so far guys.
Nazman, thanks for the pics- I'll have some more questions for you.
Steve-I'll be looking in that AIM this month (I'm still getting through the Dec issue-I read every word).
Glide- thanks for the detailed response. I have all the tools you mentioned and some of the confidence to do it myself.
My preference is to get a wide glide look including the increased rake. I'll keep my forks if possible but aren't the WG forks longer than a SG or does the rake in the trees make up for it? I know the handling will be different and it won't bother me unless I get a wobble.
Naz-- are those the stock FXD forks on yours--they look chrome to me unless you did a great job polishing them down (which I will most likely do). I think (as glide05 does) that your setup looks great with the 39mm forks.
This sucks- I'm inbetween doing this or a big bore with gear drive cams.
Old Jan 11, 2007 | 04:59 PM
Naz_Man's Avatar
Naz_Man
ORIGINAL: glide05
ORIGINAL: JSW
JSW,
You can get the kit with the top mount headlight and reuse your hood and light. The kit I got comes with everything needed including fender spacers, rotor spacer, wheel spacers, axle and trees, you will need to reuse your bearings which was no problem. As for handling, after you get the fall-away set correctly it rides just like it did before. Also you might want to have the wheel balanced because of that big spacer for your rotor. The kit I got comes in 0, 3 and 5degree rakes, I like the way my bike sits so I got the stock rake, if you go with a 3 or 5 degree you will need new longer tubes.
The tubes on my bike are stock stainless steel with chrome sliders.
Any other question feel free to ask me!
Old Jan 11, 2007 | 06:09 PM
glide05's Avatar
glide05
Correct - I visited Accutronix after I sent this and realized that there is an option to keep the stock headlamp and the "brow".
JSW - if you haven't already done so - click on Donnie's site - more fine pics.
It might be possible to rake it a bit and keep the stock forks, but you're going to have to drop the rear end at the same time to preserve the rake/trail balance. You'll end up with a shorter bike that has less clearance. Not sure if the calculations work out OK?
Old Jan 11, 2007 | 06:22 PM
JSW's Avatar
JSW
I've dropped the rear already so I wonder if I may have to get the whole front end as a kit (like purchasing a stock WG front end). I'm betting that would be one hell of a purchase (wheels and such).
I'm going to Donnie's place to see if he has a good side view of his scoot. I may be happy with what he did and not increasing the rake.
Old Jan 11, 2007 | 06:33 PM
Naz_Man's Avatar
Naz_Man
ORIGINAL: JSW
I don't have alot of pics with the new front end but here's what I do have.
http://www.donniesplace.com/htmls/donnie/dec06_1.htm
Old Jan 11, 2007 | 09:54 PM
JSW's Avatar
JSW
Donnie, the more I look at your pics, the more I like it. I thought I would want to rake it out like a WG but after reading the article about rake and trailin AIM, and seeing your pics I think I've changed my mind.
Handling is very unsafe when the trail is messed up and I have no interest in doing that.
The Seeger Cycle tech article was really informative about this topic and am going to check out their site to see the possibility of getting one of the kits they produce.
