Intermittent starting problem
Old Jun 19, 2012 | 09:26 PM
Comingapart's Avatar
Comingapart
Default Intermittent starting problem
'10 FXD
Wimmer Better Sucker A/C
V&H Big Radius 2-1
Daytona Twin Tec II tuner w/O2 eliminators
Problem started a few months ago. Occasionally, when I go to start the bike in the morning or after it's been sitting for hours, it takes forever to start.
Turn the key on, turn RUN switch on, wait for light to go out and hit the start button. Starter cranks fine but the engine just won't start. If I stay on the starter for around 30-40 seconds it will eventually start up and run fine.
19 times out of 20 I hit the button and it fires right up, but sometimes it decides it doesn't want to. The CEL isn't lit up, so I'm assuming there's no codes in there, put I haven't actually checked yet.
Any ideas?
Old Jun 19, 2012 | 09:30 PM
rooti's Avatar
rooti
I would guess its the tuner. I'm not familiar with that tuner. Is it a piggyback tuner that can be unplugged? Some people with piggy back tuners say to not wait for the idiot light to go off but to hit start right away.
Old Jun 19, 2012 | 09:37 PM
fskitch's Avatar
fskitch
try hitting the start button instantly after turning the key on. when i first went to stage one I learned this trick.
Old Jun 19, 2012 | 11:18 PM
PigInaBlanket's Avatar
PigInaBlanket
I know with a PC3 on mine it starts a lot easier if you don't wait for that silly check engine light to go out. I still don't know why people think you have to wait for that thing to go out before you can start the bike.
Old Jun 20, 2012 | 09:35 AM
Comingapart
Ok guys, I'll try that. Although I will say, I've had the tuner installed for about 18 months now and this issue just started a month or so ago.
Old Jun 20, 2012 | 02:43 PM
nevil's Avatar
nevil
Check for a leak in the tank's internal fuel line. Low fuel pressure can make it hard to start.
Old Jun 20, 2012 | 03:14 PM
BullK9's Avatar
BullK9
'11 FXDWG, oil cooler, V&H Big Shots, S.E. Air Cleaner:
I have a SE Performance Tuner installed with the above setup and I am having a similar issue - in that I wait for the light to go out, then hit the start... I'd say about 4 out of 5 times it starts fine... but then every once in a while, it'll take a bit longer (3 seconds +/-) to start-up... Sometimes when it's hot, sometimes when it's cold...
Should I also NOT wait for the light to go out?
Old Jun 20, 2012 | 03:32 PM
NPW's Avatar
NPW
Had a similar problem and it was the EFI control relay(next to the starter relay).
Old Jun 20, 2012 | 03:36 PM
BullK9's Avatar
BullK9
Thanks! I have no clue where that is, so next time I'm in the dealer - I'll have them look at an replace it since I'm still under warranty.
Old Jun 20, 2012 | 03:57 PM
NPW's Avatar
NPW
Its in the box on the left side of the bike opposite the battery that has your fuses in it. The cover has the fuses and relays labeled.
