06 street bob help please!
Old Jun 25, 2012 | 12:33 PM
badluckink's Avatar
badluckink
Stage II
Default 06 street bob help please!
I have a 06 street bob,the usb port on the powercommander got smashed bike stopped running,now ive removed the p/c but i have a set of v&h drag pipes and an aftermarket air cleaner,the pipes have no o2 bungs,so if i weld in a set will my bike run right without all the backfireing and no idle at all?i need help i cant afford to go to the harley shop for anything so here i am stuck
Old Jun 25, 2012 | 01:14 PM
8541hog's Avatar
8541hog
See my next post below, hate it when I #$%^& up
Old Jun 25, 2012 | 01:59 PM
DCLXVI's Avatar
DCLXVI
Originally Posted by 8541hog
Just adding o2 sensors will do nothing for you without an ECM or tuner equipped to read the sensors. The 06 ECM does not read o2 sensors.
Cheapest fix is probably buy some XIEDs until you can replace your tuner, or maybe the XIEDs will be all you ever need.
'06 bikes do have an O2 sensor so I'm not sure what exactly you are talking about. To the OP, you could just run the O2 eliminators that should have been there with the Power Commander and see how it runs.
Old Jun 25, 2012 | 02:00 PM
8541hog's Avatar
8541hog
I thought the o2's started on all bikes in 07 with the 96"
If I am wrong, guess it's not the first time.
So, it appears that 06 was a turning point, For 2006 HD Dyna model bikes and all 2007 later HD motorcyles, the Delphi fuel injection now operates in closed loop mode with a pair of narrow band O2 sensors.
Old Jun 25, 2012 | 02:04 PM
DCLXVI's Avatar
DCLXVI
'06 Dyna with the 6 speed has them on the 88. Also has the new style cam chains. It's kind of a hybrid year.
j.kndy68
Aug 21, 2010 09:45 PM
STSpringer
Jul 1, 2009 10:34 PM
rockon
Nov 15, 2008 12:39 PM
Rodman813
Jul 6, 2007 07:20 AM
mickeyd
Jul 18, 2006 11:12 AM
