Dakota Digital Speedometer Replacement - FXD
Old Jun 28, 2012 | 02:00 AM
drivingforce77's Avatar
drivingforce77
4th Gear
big ron, thanks for the info. I think both bikes here look great in their own right. I think the black cone blends well on big ron's bike and the oval mount fits FolsomPrisonBlues bike just as well. Swap the two and i don't think they would blend as well.
Old Jun 28, 2012 | 07:23 PM
big ron's Avatar
big ron
Originally Posted by FolsomPrisonBlues
That's certainly an option, but it still sticks up there kind of in an obnoxious way (I have an SG and used to HATE the speedo).
Here's another Dakota Digital speedo I installed on my bike, a bit more less intrusive, IMHO:
I saw those in the catalog but they did not provide a good illustration of the install. Can you see it when you are riding?
Old Jun 28, 2012 | 07:34 PM
FolsomPrisonBlues's Avatar
FolsomPrisonBlues
Absolutely! The only thing I wasn't able to get to work properly was the turn signal auto ****-off.
Old Jun 28, 2012 | 07:39 PM
big ron's Avatar
big ron
Thanks, Either way you go you will have a better looking solution than the factory set up. I have seen some guys reverse mount their stock speedo on the tank side of the risers which looks pretty good as weill. Another option is to install an Autometer speedo in the stock location or the tank side of the riser. They are 2 5/8 and can be held in place with a simple bracket that mounts to your riser bolts; the Harley stock speedo is close to 4" plus the bracket. The Autometer is WAYYYYY cheaper than the Dakota Digital Options.
Old Jun 28, 2012 | 07:46 PM
8541hog's Avatar
8541hog
If you don't have the speed sensor connected properly the auto cancel signals will not auto cancel.
Old Jun 28, 2012 | 08:05 PM
big ron's Avatar
big ron
One of the reasons I went the route I did is I wanted everything to be round. I avoided the squared of bars, irregular shaped mirrors and air cleaner to go with a common theme. I like the Dakota Digital but would have gone with an reverse mount autometer if I had done my research. I prefer the analog over digital.
Schaub85
Jun 15, 2011 10:07 PM
discodave
Mar 29, 2011 08:57 PM
Tnbrit
Nov 21, 2009 09:16 AM
whitz
Electrical/Lighting/Alarm
Jun 16, 2009 11:21 PM
songsmith
Feb 17, 2008 02:06 PM
