XIED Install ?
Old Jun 28, 2012 | 03:25 PM
tnkrizzo's Avatar
tnkrizzo
Default XIED Install ?
I just received my XIED's and installed them on my '12 Wide Glide. The rear was easy as I grounded to the motor where the battery ground connects to; however, the front was more challenging.
I grounded it to the bolt that goes through the front of the bike frame. I ran a longer bolt through it and it seems fine, but is this a strong enough ground for the front to work from?
Old Jun 28, 2012 | 03:27 PM
rooti's Avatar
rooti
That must be some new set up for the 2012's. I never had to ground mine. I don't really understand that since they are just pigtailing between the 02 sensor and ECM. I would think that would be good enough?
Old Jun 28, 2012 | 03:31 PM
AFONE's Avatar
AFONE
I just installed a set a few weeks ago. There was no grounding involved (except the beer that I had to sit on the ground while I plugged everything in).
Old Jun 28, 2012 | 03:37 PM
tnkrizzo's Avatar
tnkrizzo
Yeah, when we did my buddy's bike, it was plug and play and that was it. Took all of 3 minutes to install...not even enough time to enjoy a Skoal dip! Go figure mine has to be a 1/4 tin install...most of which time was spent figuring out where the hell to ground both ends to!
Old Jun 28, 2012 | 03:38 PM
rooti's Avatar
rooti
give nightrider a call, he'll help u out
Old Jun 28, 2012 | 04:07 PM
xantasm's Avatar
xantasm
2012's use the FL-XIED or FL VIED and yes the 2012 FL-XIED has a ground wire on it
Taken from nightrider.com
2006-2011 Dyna's use the two wire Bosch O2 sensor. This is the same two wire sensor used on most Harley-Davidson motorcycle models.
2012 Dyna's use the 4-wire heated Delphi O2 sensor. This is the same sensor used on 2010 and later Harley-Davidson Touring bikes.
So for those of you with pre '12 XIED's what yours looks like is irrelevant.
Old Jun 28, 2012 | 04:24 PM
hd2012's Avatar
hd2012
Should work as I have a 2012 Super Glide Custom and I had to ground mine. I bought some extra ground wire and spliced it in to the front one and ran the front ground to my battery but your set-up should work also.
Old Jun 29, 2012 | 06:34 AM
1HD1C's Avatar
1HD1C
thats where i have mine only to the front side, tested with a meter and it gave me a good ground on the test and so far no problems in the first 100 miles.
Old Jun 29, 2012 | 06:40 AM
Chief21's Avatar
Chief21
I grounded mine using one of the small bolts that holds the bracket for the front exhaust pipe to the bottom of the engine. Yours should be fine, it is all good metal there.
Old Jun 29, 2012 | 06:46 AM
Iceman24's Avatar
Iceman24
Just make sure you have good "metal" to that ground...I'd sand/grind off any paint so there's bare metal-to-metal on your connection...JMO.
sioux565
Oct 5, 2013 11:39 PM
pig iron
Apr 23, 2013 09:18 PM
sintax
Mar 3, 2009 07:40 PM
David96B
Dec 22, 2007 07:42 PM
