Loud backfire on start
Old Jul 4, 2012 | 05:11 AM
doc whiskey's Avatar
doc whiskey
5th Gear
Default Loud backfire on start
The other day, I went to start my bike, and when I hit the ignition, I heard a loud hollow sounding bang, along with a flash out of the tailpipe. I was standing to the side of the bike. The bang loud enough to set off some PTSD induced cursing.
I let go of the button, then hit it again and it started up just fine. The bike, a 03 FXDWG ran perfectly. Yesterday it did it again, and after hitting the ignition one more time, it started up and ran like a top.
Any idea as to what is causing this bad *** backfire?
Old Jul 4, 2012 | 05:21 AM
stilup's Avatar
stilup
Have you been washing it lately?
Old Jul 4, 2012 | 05:22 AM
doc whiskey
5th Gear
Negative. Haven't gotten any rain out here in my area for quite some time either.
Old Jul 4, 2012 | 05:46 AM
stilup's Avatar
stilup
Sounds like it's getting flooded.
Old Jul 4, 2012 | 07:20 AM
ynots's Avatar
ynots
if it back fires when its running it is usually related to timing. my guess is some gas is leaking down while its sitting. Do you twist some throttle when your start the bike. maybe the floats sticking at times? is your pet **** operated by vacuum?
Old Jul 4, 2012 | 08:34 AM
doc whiskey
5th Gear
ynots... Ill tell you the truth, I have no clue what a pet **** is.
Ill check my service manual, figure out what you are talking to and let you know. Maybe. If I can get to it.
I dont know if I am twisting the throttle. I may do that as I mount the bike without paying attention. Ill keep an eye on it.
Old Jul 4, 2012 | 09:08 AM
Wideglide103's Avatar
Wideglide103
The pet **** is a valve used to turn the gas on and off. They sometimes have an "off", "on", and "reserve" setting and are typically located below the gas tank between the tank and carb.
Like ynots said, you are most likely getting some leak down of fuel into the cylinders, which could be why you are getting the "backfire" on initial startup. I'm guessing it's probably in the carb floats.
ScottyZ
General Topics/Tech Tips
May 5, 2018 10:28 PM
Furrmyster
Engine Mechanical Topics
Dec 3, 2015 05:37 AM
Keithhu
Sep 17, 2014 07:45 AM
Brunster11
Jun 4, 2012 07:32 PM
barefoot
Feb 26, 2007 02:53 PM
