Dyna forks
Old Jul 6, 2012 | 06:35 AM
8541hog's Avatar
8541hog
Cutting the spacer would be the wrong way to go.
You are only about 50 lbs lighter than the average, so you are only about 15-20 lbs lighter on the front end, cutting the spacer will not help. Is there any difference with a full or empty tank?
Something is not setup correctly in the front end, it may have been that way before you changed the oil.
Did you thoroughly clean every part of the front end? It does not take much to clog the oil passages in the dampers. How much oil did you put in?
How much preload did you have with your current spacers?
Old Jul 6, 2012 | 06:49 AM
overhead's Avatar
overhead
Do they bang if you compress them while sitting still? I am trying to think what would bang in a fork and I am having trouble. Did you check the gas tank bolts? Maybe it is not the forks at all.
Talldog
Aug 10, 2014 07:26 AM
dennyo
Dec 30, 2013 07:48 PM
kjkustoms
Jun 25, 2012 09:21 AM
devils haircut
Dec 22, 2008 05:17 PM
