Carb troubles..
Old Jul 8, 2012 | 04:18 AM
Foxster's Avatar
Foxster
I perhaps wouldn't get hung up on the tuning here. Those jets are fine and won't cause what sounds more like a fault than a tuning issue.
It actually sounds an awful lot like the problems you get when the crank position sensor starts to go bad. But it could be a couple of things, from a bad spark plug to **** in the float bowl.
Old Jul 8, 2012 | 11:37 AM
ttopbandit's Avatar
ttopbandit
So, the Crank Position sensor wouls bring on the same stumbling and carb farts?
Old Jul 8, 2012 | 11:43 AM
Foxster's Avatar
Foxster
I've seen similar problems on a Sportster cause this when the engine is hot.
Old Jul 8, 2012 | 12:00 PM
ttopbandit's Avatar
ttopbandit
Well, I am going to bump up to a 48, and leave the 195 in there. I am buying some new intake seals tomorrow, and I will see if that does the trick. If not, I guess I will be buying a new CPS....sounds expensive....
Old Jul 8, 2012 | 12:10 PM
sonnydaze's Avatar
sonnydaze
go to the xlforums and see what a crank sensor causes the bike to run like , your bike is doing what mine did after i installed forcewinder but before i changed jets . crank sensor makes them run like crap all thru rpm range not just at idle but this is just my own experience
Old Jul 8, 2012 | 12:12 PM
sonnydaze's Avatar
sonnydaze
last one i bought was 50 bucks , think they reatail for under 80 bucks . where are you in tx ?
Old Jul 8, 2012 | 12:15 PM
sonnydaze's Avatar
sonnydaze
good read , washers are #4 brass from ace get 2
http://www.nightrider.com/biketech/hd_cv_mods.htm
crank position sensor problems
http://xlforum.net/vbportal/forums/s...ad.php?t=34308
Old Jul 8, 2012 | 12:34 PM
ttopbandit's Avatar
ttopbandit
yes, I am in central tx. thanks for links
Old Jul 8, 2012 | 01:14 PM
sonnydaze's Avatar
sonnydaze
im 60 miles east of abilene on i20 , i have the jets and intake gaskets and a table lift if your close and need help
Old Jul 8, 2012 | 01:45 PM
ttopbandit's Avatar
ttopbandit
Thanks, Bro. A little out of my way, lol, but I do appreciate the offer! God Bless.
