Forward Control Brake Pedal Issue
Old Jul 9, 2012 | 02:50 PM
Dowatt's Avatar
Dowatt
Default Forward Control Brake Pedal Issue
I have an 02 Wide Glide and I am having a very hard time reaching around my A/C with my leg. Do they make a bushing or spacer to move the brake lever outward?
Old Jul 9, 2012 | 04:27 PM
Robtarra39's Avatar
Robtarra39
Don't recall ever seeing a pedal extender, only the longer brake pedal pad as in your pic
Old Jul 9, 2012 | 11:20 PM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
I had this issue on my Fat Bob. It went away when I put foot boards on it.
Might be able to get a machinist to fab up some sort of one off thing to put the brake pedal out further.
Old Jul 9, 2012 | 11:21 PM
Steel Steed's Avatar
Steel Steed
Brake pedal height is adjustable, if that helps.
Old Jul 10, 2012 | 12:09 AM
cacolade's Avatar
cacolade
i too sort of had that problem. i got use to it. i pretty much only push the end of the brake pedal but like i said i got use to it.
Old Jul 10, 2012 | 06:28 PM
Dowatt's Avatar
Dowatt
How do I adjust the height?
Old Sep 24, 2012 | 01:05 PM
craig11dyna's Avatar
craig11dyna
I just bent the brake pedal lever over toward the foot peg so I did not have to pigeon toe the brake pad. I used a large adjustable wrench with a cloth to avoid scratching the chrome.
Old Sep 24, 2012 | 01:17 PM
blueangel73's Avatar
blueangel73
I believe if you disconnect the brake rod (threaded with a jam nut into the rear brake master cylinder) from the brake lever (runs alone the frames bottom tube), you can brake the jam nut free at the rear M/C and turn it into the MC to lower the lever and thread it out to raise the lever, reconnect the lever and see it's any better ot worse. Once you find your sweet spot finish connecting the rod to the lever and tighten the jam nut back up.
Old Sep 24, 2012 | 02:24 PM
Krazy8s's Avatar
Krazy8s
One of my winter mini projects is to find a big *** touring bike brake pedal pad and mount it to address this same issue.
That, or car brake pedal pad, one of those big ones used on automatic trans cars.
Old Sep 24, 2012 | 03:35 PM
Sammi's Avatar
Sammi
Please post your results.
Sammi
