I need some help with headlight install. Thanks
Thanks, that solves half of the problem. Now at least i know where i'm starting from
sounds very possible. Now the question is how do i determine which wire from the headlight is which without splicing every possible combination? The headlight wires do not match the yellow, white, black coming from the bike. As i mentioned, i have a multi-meter but have not had to use it so i'm not sure how to run the test on the headlight wires
Lets say the three wires from the light are red, green and blue (substitute the correct colours here).
Check for some resistance between pairs of wires, R-G, R-B & G-B. Two of these pairs will pass current and one won't. The common colour between the pairs that pass current is the ground. Example, if R-G and G-B pass current then G is common to both so the ground is G (green).
Finding the dip and main is trickier. I'd do it by trial and error. If you have a spare vehicle battery its easier, otherwise you'll need to use the bike's.
Stand the light somewhere its beam can shine on the wall and have the ends of the two non-ground wires bared.
Connect the ground you just found to the battery's neg with a bit of wire.
Then connect another wire to the battery's positive terminal and tap the other end on one of the headlight wires. Note the pattern the light makes. Tap it on the other wire. It should be fairly obvious which is then the main and which the dip wire.
