SE seat
Old Jan 19, 2007 | 01:24 PM
Ratbasturd's Avatar
Ratbasturd
Default RE: SE seat
ORIGINAL: 07 StreetBob
Off topic...did you remove the H-D tank emblems with heat? I've used hair dryer to remove the reflectors from forks and rear fender before on other bikes but now I want to take off the emblems on the tank. Hoping I can do it with just the hair dryer heat without scratching the tank.
Keith V
No, I didn't have to. I started lifting one edge with my fingers till it came loose then grabed the lifted part with vise-grips and pulled. You have to watch and make sure that the emblem doesn't fold (it is cheap as hell) and come into contact with the paint. You also need to pull the towards the direction of the end of the emblem that you started on.
example: If you start at the front you should pull at about a 20* to 30* angle away and to the front, this help keep the emblem from bending.
I did do this with outside temps at close to 80* so a hair drier could help in colder weather.
Hope that helps.
Old Jan 19, 2007 | 02:58 PM
Cornhusker's Avatar
Cornhusker
Default RE: SE seat
Yeah, that will help. That was my main concern, the cheap POS emblems bending so I'll use your method. I may wait until warmer weather anyway. Won't be waxing the bike in this weather and having to wax around them things. Thanks for the tips.
Old Jan 20, 2007 | 01:53 AM
07fxdb's Avatar
07fxdb
Default RE: SE seat
bags are BIG! - what are they?
Old Jan 20, 2007 | 02:42 PM
MrZorba's Avatar
MrZorba
6th Gear
Default RE: SE seat
Try using Dental Floss. Long piece, double if you have to, just under reflector or emblem, start one side put to back legnthwise, keep hands close to strut or tankthen use Goo-Gone for sticky stuff left over. If you have non shinny pain as in the denim veriety try the Goo Gone on some spot you cant see to see if reacts with paint.
Done all my reflectors on all bikes that way.
rickss69
Dec 13, 2012 10:43 AM
Johnny_Sack
Sep 17, 2009 05:24 PM
Shag67
Dec 10, 2008 08:47 PM
overhead
General Topics/Tech Tips
Jun 27, 2008 12:56 PM
maggiesdad
Feb 21, 2008 09:40 AM
