Dyna ecm
Old Jul 26, 2012 | 08:09 AM
cobb04's Avatar
cobb04
Angry Dyna ecm
Just before getting home yesterday my 2010 streetbob dropped to one cylinder. Cough, cough, pop,pop, bang, bang.
I left it to cool and started it up again. Started great and reved ok but once it warmed again dropped front cylinder. Engine management light also on.
Transpires the ECM is f*****d.
Has anyone else experienced this with the 2010 model.
Garage said it was common on new Dynas.
Even worse news is bike nearly 3 so out of warranty.
Cheers
Old Jul 26, 2012 | 08:38 AM
jmeiers's Avatar
jmeiers
Cheers
Someone else just posted about a similar issue just the other day. It was the spark plug wires loose.
I was going to suggest the EITMS was kicking on and causing your rear cylinder to shut down, at idle. However, I see you said the front is the issue so, check your spark plug wire on the front.
Old Jul 26, 2012 | 08:45 AM
Austin Dave's Avatar
Austin Dave
That stinks. If the garage is correct and it is a common problem, it should be rectified by the MoCo.
That module should last longer than just a few years! I'd be gettin' in the ear of someone about this faulty control unit.
Old Jul 26, 2012 | 09:57 AM
cobb04's Avatar
cobb04
Unhappy
Hello
Yes I looked at plugs and connections before resorting to garage. I have xied lead on so even removed them but same result.
Last 4 faulty ecm's at garage have been on Dynas.
Strange.
Doesn't make it any easier to accept
Old Jul 26, 2012 | 10:01 AM
Gommee's Avatar
Gommee
Devil's Advocate
A buddy's Rocker C did that a couple of weeks ago. Front cylinder shut down. Moco tried the grenade, injector, plug, plug wires. The codes did not point towards anything specific. Out come was ECM packed it in, it was just over $500 but it was covered under warranty.
Old Jul 26, 2012 | 10:10 AM
cobb04's Avatar
cobb04
Same with mine. Codes not specific, something about injector power. Mechanic put on an after marker ecm and bingo all all back to normal.
Same price quoted but then needs fitted and recoded by dealer.
Ouch!
Hey hum
Old Jul 26, 2012 | 10:17 AM
Gommee's Avatar
Gommee
Devil's Advocate
If you are running a Harley tuner, the ECM will have to be sent away to be re-married to tuner. More down time.
allsop
Jun 28, 2015 10:48 PM
HarleyGuy426
Jul 2, 2013 04:33 PM
tooldogg
Jul 7, 2012 04:47 PM
ncbrq
Feb 12, 2012 09:26 PM
biker_grunt
Apr 15, 2008 09:23 PM
