Issue with rear brake after tire install
Old Jul 27, 2012 | 08:15 PM
Simple Man's Avatar
Simple Man
Just a shot in the dark here, but did you reinstall the bushings on the same side they came off of?
Old Jul 27, 2012 | 10:42 PM
Clifford05's Avatar
Clifford05
The wheels look badass; love the look of it with the black. Really for rough alignment don't you just need a reference point on each side of the bike to measure the difference to the axle? If the alignment is off enough I would think the belt would sit in the rear sprocket wrong too.
Old Jul 28, 2012 | 12:42 AM
Tat2u's Avatar
Tat2u
something seems strange for sure. Even if the alignment was off the caliper housing pivots with the axle/wheel as its adjusted so the pads should actually stay parallel whith the rotor.
Thats some pretty major scoring on the rotor in your pic so you should be able to see whats causing it.
I just looked at mine and nothing other than the pad material comes close to the rotor?
Old Jul 28, 2012 | 05:29 AM
Stag556's Avatar
Stag556
Thanks, I'm gonna add a few red accents around the bike but nothing major.
Old Jul 28, 2012 | 05:31 AM
Stag556's Avatar
Stag556
The scoring on the rotor looks bad but actually isn't very deep at all. When I run my finger over it, I feel it but just barely.
It's frustrating because every time I remove the caliper, there are no major scoring marks inside to indicate where it's scraping.
Old Jul 28, 2012 | 07:24 AM
razors edge's Avatar
razors edge
Is the brake anchor showing any damage. That maybe where the contact is taking place. just a thought
Old Jul 28, 2012 | 08:43 AM
Stag556's Avatar
Stag556
Are you referring to the bracket that holds the caliper to the axle itself?
Old Jul 28, 2012 | 09:10 AM
Tat2u's Avatar
Tat2u
Caliper housing to swingarm, check that's not fouling
Old Jul 28, 2012 | 09:41 AM
razors edge
Re move the wheel you will see it.it's there somewhere
Old Jul 28, 2012 | 09:42 AM
razors edge
The wheels are sweet
