Issue with rear brake after tire install
Old Jul 28, 2012 | 09:45 AM
razors edge's Avatar
razors edge
Did you change wheel bearings?
Old Jul 28, 2012 | 09:53 AM
Neenjah's Avatar
Neenjah
I had the same issue, they clamped the tire machine to your rotor when they changed the tire and it bent the rotor.
Straighten it.
Old Jul 28, 2012 | 10:05 AM
Tat2u's Avatar
Tat2u
Straighten it.
Bloody hell that's rough workmanship if they did that but still the pad is the only thing the rotor should be contacting, bent or not
Old Jul 28, 2012 | 10:12 AM
razors edge
my brother in law had issue that are simular to your issue. long story short the wheel bearings were not properly located in the wheel hub. when you press on the brake pedal it pushes the rotor into the brake anchor.
Old Jul 28, 2012 | 10:14 AM
razors edge
thats his living room you see my bike parked in the picture, was not enough room in his garage when i came to see him so i just parked it in his living room.
Old Jul 28, 2012 | 11:15 AM
Stag556's Avatar
Stag556
No, the wheel bearings were removed for powder coat them installed again.
Old Jul 28, 2012 | 11:16 AM
Stag556's Avatar
Stag556
Straighten it.
The rotor was not on the wheel when the tire was mounted.
Old Jul 28, 2012 | 04:26 PM
razors edge
ok you pull the wheel bearings and then reinstalled them? if the are not installed correctly the hub is not properly located on the axel. i belive the wheelbearing on the rotor side should be at the bottom of its boss and the spacer will be next and then the other wheel bearing pressed in to the spacer, has no slack/play what ever you want to call it. get a manual and read it on wheel bearing installation. i bouht new wheel bearing at a local bearing store for 20 bucks a pop, cheap insurance for me.
Old Jul 28, 2012 | 10:32 PM
Stag556's Avatar
Stag556
A quick update to this... I removed the new wheel and reinstalled the old wheel...it works perfectly fine. So I have eliminated anything on my bike as the problem and narrowed it down to the new wheel.
The obvious culprit are the wheel bearings so I'm gonna remove them and reinstall. We'll see how that works.
Old Jul 29, 2012 | 01:32 AM
Redhill Phil's Avatar
Redhill Phil
Could it be as simple as mixing up the spacers ? The one on the right is heaps wider than the left going by the service manual.
