Super Glide shock question
Old Jul 30, 2012 | 10:15 AM
Pigger's Avatar
Pigger
3rd Gear
Default Super Glide shock question
Hello! New user here.
I have an 08 Super Glide. The woman I bought it from lowered it. I want to raise it back up. The standard size shocks are 12". I can buy a pair of 13.5" Progressive 412 shocks at a good price. Will they fit?
Old Jul 30, 2012 | 10:45 AM
SPECIAL ED's Avatar
SPECIAL ED
The best answer I can give you is probably.I have 13" Ricors on my 06 right now and they fit no problem.
Old Jul 30, 2012 | 11:13 AM
Vaquero.45's Avatar
Vaquero.45
Progressive doesn't list a 13.5" 412 for the Super Glide. They do list a 440-4040 for that bike in 13.5", which means that a 13.5" shock is okay in general, but the 412's you have in mind may be for something else and may have spring and damping rates that don't work so well. If you have the 4-digit submodel number, e.g., 412-4037, you can look them up here, compare them to the 440-4040 and see if they're close.
Old Jul 30, 2012 | 11:14 AM
Vaquero.45's Avatar
Vaquero.45
BTW, 12" is stock, and 13.5" is pretty darn long, but that may be just what you're after.
Old Jul 30, 2012 | 12:43 PM
Pigger's Avatar
Pigger
3rd Gear
I'm 6'9" so I need it up off the ground. Already put the forward controls on. Man did they make a difference! I'll have to keep researching the 412's to see if they'll fit.
Old Jul 30, 2012 | 04:03 PM
sk8's Avatar
sk8
Stage III
if your're a heavier guy, i have been instructed to get a longer than stock shock. next year i'm going to redo my suspension with works perfromance. Tom at works has been extremely helpful.
my biggest complaint about my dyna is the stock suspension when riding 2 up, we always bottom out, and we are not large people, but we are over harley gvwr for the bike.
Old Jul 30, 2012 | 04:22 PM
stev0n's Avatar
stev0n
I have progressive 412 Heavy Duty shocks in 12" on my 08 fxd. Half an inch lower than stock. I'm 290ish pounds & 6'3" & my girl is 150ish. We are over the GVWR rating by like 60lbs. On the softest setting we've never bottomed out, but the bike is still higher than i would like it to be so I am going to try 11" standard progressive.
Old Jul 30, 2012 | 04:25 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I put the 13.5" Progressives on the wife's sporty low as it was too low. I don' have the part number here but they bolted right on. Without issue. I prefer to be higher off the ground so I don't scrape so easy in the corners. I would imagine the 13.5" shocks should fit fine. If you are 6'9" you want even taller shocks like 15".
Old Jul 30, 2012 | 04:36 PM
rooti's Avatar
rooti
If you are 6'9" you want even taller shocks like 15".__________________
I've never heard of anybody putting anything taller then 13.5 on the dyna....that would look stupid, plus I would think it would throw off the front suspension as well
Old Jul 30, 2012 | 06:07 PM
lo-rider's Avatar
lo-rider
Call Progressive.
Cbb129
Dec 7, 2015 10:42 AM
nanook
2014-2024 Touring Models
Aug 2, 2015 10:17 PM
Pigger
Aug 8, 2012 04:32 PM
jm209
May 17, 2008 08:58 AM
Frankster69
Jan 3, 2008 05:24 AM
