drain plug?
Old Aug 2, 2012 | 08:50 PM
NhHarley's Avatar
NhHarley
6th Gear
Default drain plug?
Ok i just bought a 2005 super glide 1450. on the brake side of the motor on the bottom there is a small hexhead plug/screw. I removed this while doing an oil change and oil came out. i know this is NOT the drain hole thats why im wondering if anyone can tell me what it is.
Thanks Mike.
Old Aug 2, 2012 | 09:05 PM
nevil's Avatar
nevil
Does it look something like this?
You really need to get a service manual.
Old Aug 2, 2012 | 09:20 PM
NhHarley's Avatar
NhHarley
6th Gear
no much smaller and further up motor. I ordered a service manual.. not here yet. i want to ride..
More under the center of the 2 cylinders. on brake side
Thanks Mike.
This is my first harley and im in love i cant get off it long enough for vibrations to leave my body lol.
Old Aug 2, 2012 | 09:26 PM
NhHarley's Avatar
NhHarley
6th Gear
Its a "grub screw" if you know what i mean with a hex in it.
Old Aug 2, 2012 | 09:31 PM
nevil's Avatar
nevil
Does this help? Except for the dead cat location, of course.
Old Aug 2, 2012 | 09:33 PM
NhHarley's Avatar
NhHarley
6th Gear
I cant see the pic you put up. but its no where near the real drain hole locations. Its directly under cylinders/push rod location. Its a recessed grub screw with a hex for acces. very bottom of motor. have to lay on back to see it.
Thanks Mike
Old Aug 2, 2012 | 09:48 PM
soft 02's Avatar
soft 02
Thanks Mike
I believe thats the one that people end up cracking there case removing or installing. Not sure its purpose. I would leave it alone.
Old Aug 2, 2012 | 09:54 PM
NhHarley's Avatar
NhHarley
6th Gear
lol i took it out due to bad advice and i already reinstalled it with no cracking. i just really want to know if the oil that came out was replaced by the oil change i did or not. and is it just another drain for teardown or deos it have a purpose like allowing flow of oil or such.
Thanks Mike
Old Aug 2, 2012 | 09:57 PM
soft 02's Avatar
soft 02
Thanks Mike
Pretty sure there is no normal reason to remove it. With a dry sump style pump there should be very little oil in there.
Old Aug 2, 2012 | 10:00 PM
NhHarley's Avatar
NhHarley
6th Gear
I ask because i did an oil change and got oil from harley 20-50 syn and took out nasty thin oil and now my motor seems to stay to hot to keep hand on for 3 hours after a 1 hour ride in 80 degree weather with decent humidity. any ideas?
Thanks again guys being new to a bike/atv/car really sucks while waiting the arrival of service manual..
Mike
