Speedo, tach, horn, directional stopped working
Old Aug 6, 2012 | 04:10 PM
Frank1911's Avatar
Frank1911
Default Speedo, tach, horn, directional stopped working
Help....
I have a 2004 Dyna low-rider (carb version) that I just purchased and it has been awesome....however today I ran into some pretty strong storms and after getting totally soaked about three times, I noticed that my tach had stopped working....shortly after the speedo stopped as well. Further checking revealed that the horn, directionals, brake light and odometer were not working as well. Additionally the turn signal are on steady on both sides.
The headlight and taillight work and the bike runs fine.......It has dried out now and is still the same.
Fuses (that I can fine) are good.
HELP.....
Thanks
Old Aug 7, 2012 | 06:47 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by Frank1911
Help....
HELP.....
Thanks
I'd change the accessory and instrument fuses to begin with.
If this doesn't help, check if you have power at pin 1 (orange/white) and pin 6 (orange) at the 12 pin harness ==> speedo connector.
If no power found at the harness connector pins 1 and 6, take off the fuse board to check for power, corrosion and bad connections
Old Aug 7, 2012 | 09:38 AM
Baeseman1's Avatar
Baeseman1
Believe it or not, I had something very similar recently. Long story short, it was in my ignition switch. There was enough corrosion on the contacts they weren't making good contact. Once I cleaned the **** out of em and put it back together, it's been flawless.
I can't remember, does the Low Rider have a dash or neck mounted ignition switch?
thorsmith59
Jun 20, 2012 05:29 PM
wiseguy2day
Jun 27, 2010 01:09 PM
noreastermma
EVO
Aug 17, 2008 09:37 AM
noreastermma
Aug 5, 2008 08:47 AM
04RoadKing
Jul 8, 2006 04:16 PM
