Is this normal?
Old Aug 11, 2012 | 03:47 AM
Daniel_p's Avatar
Daniel_p
Default Is this normal?
This is my first bike ever and I am definitely not mechanically experienced. So just wanted to know if this was normal.
Right behind and under my oil cooler a lot of gunk??? if that's what you'd call it, builds up:
Problem Area Outlined in Red:
Also on the transmission, engine, and near the oil cap stuff keeps showing up after every time I clean it up:
Just wanted to know if I need to have this checked out or if this is to be expected.
Help appreciated!
Old Aug 11, 2012 | 04:20 AM
Redhill Phil's Avatar
Redhill Phil
A little hard to say. Most or perhaps many motors will weep a very small amount of oil over time. If you wash your bike regularly you don't really notice it. It looks like you may have leak somewhere. Get a good de-greaser and clean all the oil off. Then check that your oil filter is done up snug. It only needs to be as tight as you can do with your hand. Then warm the bike up and go for a short blast, maybe a couple of miles, stop and closely inspect the motor. Start at the front, because any oil thats leaking will run back over the hot engine and spread. Keep us posted mate
Old Aug 11, 2012 | 05:32 AM
dyna rider's Avatar
dyna rider
Default Oil Changes
If you are doing your own oil changes, or if your dealer is doing them, you need to use brake kleen on the front motor mount and that area after an oil change. It cleans up the drips from the filter removal which can cause all the areas you highlighted. If you do that and keep it clean, it will be easier to see where it is coming from. You can also use baby powder to detect leaks. You also need to change the hoses to the oil cooler at least every 5 years or so.
Old Aug 11, 2012 | 06:21 AM
Redhill Phil
Have not heard the baby powder solution before, but that's fu*kn brilliant mate and you are right about cleaning up after an oil change. That little bit of spillage can spread far and wide once it is warm.
Old Aug 12, 2012 | 08:45 PM
HD7585's Avatar
HD7585
Spray anti persspirant works well to find oil leaks also.............spray the area white and go for a ride
Old Aug 12, 2012 | 08:51 PM
DonN's Avatar
DonN
Use those brake cleaners or strong degreasers sparingly and do not get them on your rubber engine mounts or you may eat them away. But then, oil on the mounts also causes problems so find them problem and fix it once rather than continually degreasing.
Old Aug 12, 2012 | 09:39 PM
7mag's Avatar
7mag
Maybe a pin hole in the oil cooler or a fitting needs tightening?
Hey Redhill are you a Kiwi?
Flying Horse
Aug 14, 2016 12:37 PM
Buns79
Feb 28, 2016 07:57 AM
Glid'nThruLife
Nov 29, 2014 11:29 AM
teamdooracer
Mar 15, 2011 03:20 PM
2d3k2h
Mar 25, 2009 08:28 PM
