FXDXT Bag Locks - Another Method
Old Aug 12, 2012 | 04:28 PM
schwarz633's Avatar
schwarz633
Default FXDXT Bag Locks - Another Method
Inspired by the solution offered by LeatherPro, I decided to see if I could come up with what I consider to be a slightly cleaner method:
https://picasaweb.google.com/1085234...eat=directlink
Old Aug 12, 2012 | 06:18 PM
jslum's Avatar
jslum
So instead of it being a lock that turns into place the plunger engages and keeps the bags from being removed?
Old Aug 12, 2012 | 06:57 PM
schwarz633's Avatar
schwarz633
Yes, the plunger locks in the extended position and blocks the bag mounting pin from sliding to the big end of the slot, where it needs to be to remove the bag.
The washer on the inside is tapped for the two screws. The locknuts could be removed, but it would be difficult to remove the screws. Even if you could get the screws off, the lock couldn't be pushed through the hole in the plastic, because the plate on the lock is right up against the end of the mounting pin.
Obviously, given enough time, tools and and persistence any lock can be defeated, but I'm confident that this will foil the casual passing opportunist.
Old Aug 12, 2012 | 08:43 PM
Bo_Jangles's Avatar
Bo_Jangles
Looks good and a little less degree of difficulty. Any chance you can write out a parts/price list and where you got all the items?
Old Aug 13, 2012 | 08:52 AM
schwarz633's Avatar
schwarz633
I'm not too sure about the less difficult part, you do need to remove the top 2 pop rivets in order to get the lock mounted. So you need a pop rivet tool that will work on 3/16" rivets. I have this one from Harbor Freight:
http://www.harborfreight.com/hand-to...tle-66422.html
Locks from Amazon
Amazon Amazon
The red plastic band around the lock barrel is a cut-down Caplugs EC-12 that I had laying around. It fills the small gap between the lock barrel and washer hole.
http://www.caplugs.com/productdetail...emno=EC+SERIES
Everything else from McMaster-Carr
92141A056
18-8 Stainless Steel General Purpose Flat Washer, 3/4" Screw Size, 1-3/4" OD, .09"-.12" Thick, packs of 10
per pack 5.96
97525A635
18-8 Stainless Steel Blind Rivet with 18-8 Stainless Steel Mandrel, Wide Domed, 3/16" Diameter, .126"-.25" Material Thickness, packs of 25
per pack 8.57
7377A44
Tamper-Resistant Torx Insert Bit, 1/4" Hex Shank, T10, 1" Length
each 3.86
91870A148
18-8 Stainless Steel Tamper-Resist Flat Head Machine Screw, Pin-in-Torx, 6-32 Thread, 1/2" Length, packs of 25
per pack 8.97
91831A007
18-8 Stainless Steel Nylon-Insert Hex Locknut, 6-32 Thread Size, 5/16" Width, 11/64" Height, packs of 100
per pack 4.88
I have enough of the hardware stuff left over to do 8 bags, PM me and we can probably work something out so you don't have to buy more than you need like I did.
Old Feb 2, 2017 | 12:22 PM
JHobbs1's Avatar
JHobbs1
Stage II
Locks from Amazon
http://www.amazon.com/gp/product/B00...=AYETLLJ1Q9FG5
92141A056
per pack 5.96
97525A635
per pack 8.57
7377A44
each 3.86
91870A148
per pack 8.97
91831A007
per pack 4.88
If you have a kit left out of the materials you bought, let me know, id be interested. Thanks
Old Feb 2, 2017 | 12:28 PM
cggorman's Avatar
cggorman
Just out of curiosity, how did you come up with caplugs as a supplier?
I do packaging at my job and use them (and Essentra Components) but I was surprised to see them mentioned here...
Old Feb 6, 2017 | 02:00 PM
crtman21's Avatar
crtman21
Schwarz,
Looks good man. I always wanted to do something to get rid of that locking mech in the stock bags. I like the look of this. If you have any more kits, I'd be willing to get one from you.
blackflame
Jul 26, 2012 09:27 PM
Rattletrap 96
Jun 26, 2012 07:29 PM
redrocker
Jun 4, 2010 12:59 PM
hog-doc
General Topics/Tech Tips
Apr 27, 2010 05:28 PM
skywagon
Mar 6, 2005 04:06 PM
