Changed grips screwy throttle
Old Jan 22, 2007 | 08:58 PM
Nach's Avatar
Nach
Default RE: Changed grips screwy throttle
What do you need pictures of alaska bobber??
Old Jan 22, 2007 | 11:54 PM
phreak's Avatar
phreak
ya know..... when i swapped out the throttle and idle cables, i phound that if the cables weren't in just the right place, the return either didn't work, or was very slow.
maybe try moving the position of the cable routing, and play with the throttle, see if you can phind one where the return works better.
you didn't happen to take the whole thing apart did you?
change the routing of your cables?
Old Jan 24, 2007 | 08:50 PM
Timmer's Avatar
Timmer
ORIGINAL: jaxdwg
Yep; go down to the carb/throttle body and put the return cable back on the rotator sheave, the bottom end of the cable probably fell out of place. Next time get a couple pairs of hemostats and clamp the cables in the taught position at the grip so the bottom won't come out when changing cables on the grip, don't ask how I know----jack
Jax, any advice on how to get the F&*^#n throttle assembly back together???? Lost another one of the ferrules tonight.[:@]Is it easier to take the throttle cable off down at the throttle body????Threw the cover on it and said the he!! with it. Tim
geost
Dec 27, 2014 08:36 AM
user_1534GD
Jul 11, 2013 05:38 PM
scot210
May 4, 2011 07:29 AM
oldguyriding
Jan 14, 2008 06:15 PM
saltlick
Feb 20, 2007 06:35 PM
