Candlepower Inc.
Not having the funds for an LED conversion, I decided to contact Candlepower Inc. recomended by a moderator, a couple years back. (wescoot2) Checking the website, I ordered the recomended 5-3/4" replacement assembly #H402212SBL. Shipped priority mail, it arrived two days later. Total price was about $62.
Installing it, I noticed that it's somewhat lighter than the stock assembly. The lens and reflector are made in Japan (Surprise! They aren't from China.) And the H4 bulb that came with the unit, is from Narva. Being leery of lesser known bulb makers, I decided to retain my nearly new Sylvania.
Installation is straight forward, although I had to forgo the 'park' light feature in the stock reflector. And the assembly didn't tighten down, as secure as I'd have liked, without a couple wraps of electrical tape under the bezel.
The installed lens is nearly flat, unlike the rounded OEM unit it replaced, so some nostalgic folks may not like the 'sealed beam' look of it. And in the daylight, it has a slightly cloudy look... almost light blue, though it did not cast a blue light when turned on.
At night, this thing ROCKS! Commuting on two-lane roads, I am primarily concerned with the low-beam on any given setup, and this works better than expected. I have three to four seconds of headlight, traveling up to 50 mph. The beam is wide (nearly two lanes), and devoid of most shadows. Critters on the sides of the road, show up pretty well.
The high beam casts a light far out into the distance, but signs reflected back too much glare, for me to evaluate it. Another night, on a more open desert, will be required.
The replacement lens came packed in a sturdy carton, via USPS, with instructions and a hand-writen thank you note, from Candlepower. Let's see Motorcycle Superstore do that.
I'm ordering another lens and reflector for my wife's Sporty... maybe I'll give it a try then.
