cam chain
Old Nov 25, 2022 | 05:32 AM
stilup's Avatar
stilup
When I did my cam swap, I installed Zippers Red Shift Dual Piston Chain Tensioners.
The stock tensioners had about 1/5 worn by eye at 20K.
When I bought my Zippers they came as a kit with the Axtell oil bypass valve upgrade, I installed that too.
I see the new Zippers Cam chain tensioners don't have that option now.
They are more expensive now but what isn't? Last year I bought new Zipper inserts to swap out in the future.
Almost 40K on the clock and haven't looked at them. I plan to look at about 70K.
Old Nov 25, 2022 | 09:43 AM
Blue Bob's Avatar
Blue Bob
It's not so much a wear issue but a degrading of the shoe itself. Plastic gets hard and cracks with age.
Old Nov 25, 2022 | 01:31 PM
Ddjjss's Avatar
Ddjjss
6th Gear
[QUOTE=stilup;20945286]When I did my cam swap, I installed Zippers Red Shift Dual Piston Chain Tensioners.
Almost 40K on the clock and haven't looked at them. I plan to look at about 70K. DDdjjss hello not sure if you received my message. I am new on this. Just wanted to say thank you for that information. I have seen those tensioners before they look like they will do a lot better job. I’ll remember that when I pick up my conversion kit in a week . I am putting wood to W6 Kim chefs in with new can play oil pump sprockets change total conversion. I will pick up those double cam tensioners they look very strong. Thank you again.
Old Nov 27, 2022 | 04:56 PM
Two Lane Tramp's Avatar
Two Lane Tramp
No need with 08. Whole new setup. maybe check them at 60K
Old Nov 28, 2022 | 08:25 AM
Blue Bob's Avatar
Blue Bob
I would not trust it. Again plastic gets hard with age.
Old Nov 30, 2022 | 07:05 PM
Two Lane Tramp
Well lets see, I converted my 01 WG at 20K, sold it at 100K no problem. I converted my 04 EG at 30K sold at 80K no problem. Bought 15 RG new, rode 60K no problem. Just sayin!
Old Nov 30, 2022 | 07:45 PM
2500hdon37s's Avatar
2500hdon37s
And for the sake of just sayin' on an old thread, I'll add that riding style can make a huge difference in cam chain tensioner wear. A guy who leisurely cruises down back roads and interstate keeping his engine RPM let say an average of 2600, is usually going to get optimal life and good wear out of his cam chain tensioners. Vs a guy who rides his bike aggressively keeping engine/ oil temps hotter and keeping his engine RPM average much higher while riding fast in twisties or high interstate speeds is going to see much more wear on the tensioners even when compared to equivalent mileage of the other rider.
I had cams in my '14 done earlier this year with a little more than 24k miles on my bike and the original tensioners were absolutely in need of replacement when the cams were done. I tend to be the second guy in my example. So for myself I would consider a 25-30k mile maintenance interval on tensioners, or 10 years. whichever comes first.
Old Dec 1, 2022 | 06:45 AM
OakMountainRider's Avatar
OakMountainRider
Old thread here, but important subject, I guess. I replaced cam, cam plate, pump, cam tensioner pads last winter on my Dyna 2006 at around 13.000 miles, and although my tensioners are hydraulic, one of them were pretty much worn.
This was a surprise, but I think it was caused by low oil pressure and sumping, which I experienced before replacing the components. (At times when the engine was hot, I used to have the red oil light flickering at idle and bike was also dull and lethargic in throttle response, even when just reaching normal working engine temperature.)
I think the hydraulic tensioners are pretty good, but they probably need sufficient oil pressure and good circulation to work well. At idle my pressure were down under 3 PSI at hot engine. Now I have never seen it under 10 PSI - not even after been sitting long in traffic jams at really hot summer days.
This is only my own guess off course, but it seems logical to me. Low oil pressure and sumping cannot be good to any engine.
Old Dec 2, 2022 | 04:50 AM
OakMountainRider
This is how my outer pad looked like. Although in a hydraulic tensioner, the pad has started to break down.
Fred_HD
2014-2024 Touring Models
Feb 28, 2018 08:11 PM
Two Lane Tramp
19
Jan 24, 2018 08:59 AM
Keitht
Feb 24, 2011 05:20 PM
whitepearl
Exhaust System Topics
Aug 25, 2009 02:15 PM
Mr Wonderful
Jun 17, 2006 07:50 PM
