Need some advice
Old Sep 1, 2012 | 04:41 AM
Foxster's Avatar
Foxster
Originally Posted by DK Custom
They can't make it right...or least it is illegal for them to. HD dealers legally cannot map a bike to run richer than 14.6:1 per EPA regs.
This will result in surging, hesitation and running hot. It will not damage them, but it is less than a satisfactory riding experience.
Easy, inexpensive, fast fix is the XiED. You can read all the details about it HERE.
The Plug-n-Play XiED richens the Air Fuel Ratio from 14.6:1 to 13.8:1 in closed loop mode.
For a 2012 Dyna I think he'll need the FL-XIED®-10 because of the smaller O2 sensors.
Also, to be a tad pedantic, the richest these will achieve will be about 14.0:1.
(By the way, Kevin...had some Triple Trap pegs from you recently - they are great! Thanks).
Old Sep 1, 2012 | 05:47 AM
Redhill Phil's Avatar
Redhill Phil
Dealer should be the one to sort this issue mate
Old Sep 1, 2012 | 07:49 AM
JVDeuce's Avatar
JVDeuce
Just remember.......even for some of the easier jobs "Mr. Murphy" will show up. And for $237, just do it! Drop off, pick up and have FUN
Old Sep 1, 2012 | 02:07 PM
SIREx's Avatar
SIREx
[QUOTE=Foxster;10277466]A good ending. They putting some SE slip-ons on now?
This is a good lesson for anyone going this route. Short shots are just not good pipes, performance-wise. They are a lousy design for anything other than looks and they perform worse than the stock pipes on the dyno at all but red-line revs.
Also, the dealer stage-1 map is a complete and utter waste of money and no one should ever consider it. All it does is raise the rev limiter a little - that's it, nothing else. The bike can cope with stage-1 pipes and air cleaner just as well for free.
So, a bad combo of parts.
I'd recommend taking the advice given earlier and fit yourself some Xieds once its done. You can always whip them off if you are bothered about them during any warranty work. The bike will run much better with them for as long as you run without a tuner.[/][quote]
Amen brother!
Yes they are giving me the SE slip-ons.
I am not interested in lots of power just a little louder sound without all tweaking. If I wanted to go fast I would have bought a rice burner like had when I was a kid.
Lesson learned for Sure. I should have found a very nice older carburated model with low miles, but impatience got the best of me and I wanted a warranty.
Plus my wife gave me the ok on my 20th wedding anniversary so I did give her a chance to change her mind.
How much difference do the XIEDs really make? I will do some research.
Thanks for all the comments guys.
Old Sep 1, 2012 | 05:49 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Hey, thanks for the catch.
Yes, it would be the FL-XiED-10 or the FL-ViED-10 for the 2012 Dyna...not the XiED.
The FL-ViED-10 will go a little richer than the FL-XiED-10
LINK to all the XiED family.
The Plug-n-Play FL-ViED-10 richens the Air Fuel Ratio from14.6:1 to a range of 14.3-13.9:1 in closed loop mode.
Thank you for the feedback on the Triple Traps. That is what I am running on both of my bikes right now!
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Sep 1, 2012 | 05:54 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
[quote=SIREx;10278896]
Immediate Benefits:
  • Lower Engine Temperature
  • Lower Exhaust Temperature
  • Improved Throttle Response
  • Reduced Surging
  • Reduced Pinging
The FL-ViED-10's are a cost effective alternative to an aftermarket tuner & dyno runs. FL-ViED-10's will cool your bike down and make it run better.
There is an indirect richening of the open loop fuel mixtures through the learning mode, or adaptive fuel value action built into your ECM. This ensures the richer 13.8-12.5:1 AFR's are ALSO adjusted in heavy/full throttle operation.
Springer66
Milwaukee Eight (M8)
Jul 7, 2017 11:42 AM
JohnTM
Jun 7, 2013 08:54 PM
mswing1234
Sep 23, 2011 04:28 PM
polo135
Jun 29, 2008 08:04 PM
Fuente
Mar 4, 2005 09:17 PM
