Bad gas or?
Old Sep 10, 2012 | 05:48 PM
razors edge's Avatar
razors edge
I would say that you moved the problem there for you are not wasting your money.it sucks it cost as much as it does but at least you know the problem.
Old Sep 10, 2012 | 05:50 PM
razors edge
Fuel filter is cheap insurance
Old Sep 10, 2012 | 08:09 PM
oldman9's Avatar
oldman9
Implying you think its worth the trouble? Id like to do it any way.
Old Sep 10, 2012 | 10:10 PM
razors edge
the fuel filter does need to be changed, i don't belive its going to solve the problem with the injector. since you moved the injector from back cylinder to front cylinder and now the front cylinder is not running you have found the problem. damage done why did it fail, trash maybe, there are several things it could be inside the injector. if you want, move the bad injector back to the rear cylinder. see if they exchange these injectors, just a thought.
Old Sep 10, 2012 | 11:51 PM
oldman9's Avatar
oldman9
I know this....
I was only saying that apparently something got into my injector so I might as well replace the old filter a new clean one to help insure the new injectors don't go bad the same way.
The area I live and work in has very crappy quality gas any way, so anything will help.
Old Sep 19, 2012 | 02:49 PM
oldman9's Avatar
oldman9
So after days of scratching the ol' brain..... I got it running.
I replaced the filter and rigged up a can of cleaner to it and flushed them out....for a second time. My 10 year old son ask me to exsplain how the valves work.
THE REAR CYLINDERS PUSH RODS WHERE IN BACKWARDS!!!!
I swap them out and it starts right up....
Old Sep 19, 2012 | 02:58 PM
lo-rider's Avatar
lo-rider
Buy the service manual.
Arend
Engine Mechanical Topics
Feb 19, 2015 04:41 AM
maldito85
Shovelhead
Jun 21, 2012 01:44 PM
mikeault
Jun 18, 2010 08:32 AM
bama6977
Mar 23, 2010 08:28 AM
