Suspension question
Old Sep 4, 2012 | 12:45 PM
spanky02's Avatar
spanky02
Default Suspension question
My front suspension was bottoming out so I had the fork oil replaced.. The dealer said the fork oil was fine and either my springs r shot or there r lowering springs in it... It not as bad now but my front end still dives pretty hard when braking.. What do u guys think
Old Sep 4, 2012 | 12:46 PM
spanky02's Avatar
spanky02
My bike is a 96 superglide that I bought A couple months ago 25000 on it when I bought it
Old Sep 4, 2012 | 12:52 PM
JRK5892's Avatar
JRK5892
if the springs are sacked out really only option is to replace them... you can also try to run a bit thicker fork oil like 15w but if the springs are shot that will not fix anything
Old Sep 4, 2012 | 01:17 PM
OldTyme's Avatar
OldTyme
Is replacing the springs as easy as taking the top off of the forks?
Old Sep 4, 2012 | 01:31 PM
ian03xl's Avatar
ian03xl
I have a similar situation with my low rider the springs are weak. Temporarily I changed the dork oil to 10wt and made a 5/8 spacer to go between the cap and spring for more pre-load actually works quite well. I'm planning a full on suspension upgrade later this year. You should have about 25% sag in the front forks when sitting on the bike in full gear. Mine was close to 40% and now its at 23% this is what worked for me anyways.
Old Sep 4, 2012 | 01:35 PM
DCLXVI's Avatar
DCLXVI
Heavier oil will not make up for a weak spring. In some cases it could be worse. All heavier oil does is slow the suspension movement. If it slows it too much then you get poor handling. Still not a replacement for a properly selected spring.
Old Sep 4, 2012 | 02:18 PM
spanky02's Avatar
spanky02
i will just replace the springs.. im looking at progessive stock height springs. anyone running these?
rhallman
Apr 27, 2019 08:13 PM
SuperG96
Nov 6, 2016 10:43 AM
cmonster
Jun 22, 2009 11:52 AM
WildBillAce2
May 20, 2009 12:49 AM
BluePotato
Jul 8, 2008 09:00 PM
