Brake Master Cyl paint peeling ....
Old Sep 9, 2012 | 12:43 PM
hboat's Avatar
hboat
I hope Joe's pics are from Vegas. Those are the ones I want to see...
Old Sep 9, 2012 | 08:26 PM
RBC31820's Avatar
RBC31820
That is not a bad idea Tim. Definitely something to think about. So if I read it correctly there is nothing special needed to rebuild the master cyl you just have to make sure not to mix dot 4 and 5. The seals will work for both dot 4 or dot 5 correct?
Old Sep 10, 2012 | 06:20 PM
Harley Tim's Avatar
Harley Tim
The seals are the same. The issues are with allowing even a small amount of DOT 4 remain in the system. I'm sure some "Experts" will chime in on this saying the components must be disassembled, and thoroghly cleaned, but this is what worked for me; The system MUST be thoroughly flushed. To not do this could compormise the performance of your brakes, and put your health and welfare at risk.
I used a "power bleeder" to insure that ALL DOT 4 was removed. Just watch what comes out of the bleeder nipple with a short lenth of clear tubing slipped on it, into a "catch can", You'll see a distinct difference in the color of the fluid. Pump the brake lever a few times during this process to insure that all the old fluid is flushed from the caliper as well. And then...Do it all over again just for good measure.
Note; If you're running a dual disc in the front, be sure the bike is in an up-rite posistion (Not on the jiffy stand).
Short of disassymbling the master cyclinder and caliper, that's it. This worked for me, and that's been some years ago.
Hope this helps,
Best wishes....Tim(HT)
Old Sep 10, 2012 | 09:39 PM
RBC31820's Avatar
RBC31820
Thanks for the info Tim. Looks like I have a project for this winter.
Old Sep 11, 2012 | 09:53 AM
JRK5892's Avatar
JRK5892
here is a shot of my controls, everything (master, clutch perch, and switch housings)
looks even better with rocket bobs top caps
Old Sep 13, 2012 | 09:45 PM
RBC31820's Avatar
RBC31820
Thanks for the pics Joe. The gloss black is kind of growing on me. Definitely something to think about. I will PM you when I decide what I am going to do.
gnafin
EVO
Jun 18, 2018 09:39 PM
hd4evr2008
May 26, 2018 09:55 AM
ultra_classic
Feb 7, 2016 10:39 AM
RBC31820
Feb 28, 2012 12:07 AM
Ultra Dare
Sep 23, 2011 10:40 AM
