shock fitment
Old Sep 11, 2012 | 07:58 PM
brown dawg's Avatar
brown dawg
Default shock fitment
my buddy has an 82 wide glide i told him id give him my stock shocks off my 09 fxdc the 82 shocks measure 12in eyelet to eyelet the 09 12 1/2 i think it will work my ? is any adj needed on the chain to comp for xtra 1/2 and the top mounting bolt on the 82 looks alot smaller than the 09
Old Sep 12, 2012 | 08:27 AM
grbrown's Avatar
grbrown
Wink
Just take care when fitting them to the older bike check to see if they need spacers at one end, don't just bolt them up. After fitting them check chain tension and adjust if necessary. If the swingarm axle is lower than the rear wheel axle the chain will tighten very slightly, if the swingarm axle is higher the chain will loosen a little, but not much in either case IMHO.
Bagger11
2014-2024 Touring Models
Aug 15, 2017 05:35 PM
LQQK_OUT
Mar 21, 2016 09:09 PM
Bowhunter8607
Mar 14, 2015 11:41 AM
Wi_Duker
Jul 15, 2013 11:25 AM
conn.rod
Ironhead
Apr 25, 2011 01:21 PM
