98 FXD topping out at 90mph
Old Sep 13, 2012 | 02:59 PM
8541hog's Avatar
8541hog
Welcome to the forum...
Sounds like a good thorough carb job is in order, but a new air cleaner I bet would make a difference. I like stating the obvious....
Old Sep 13, 2012 | 03:05 PM
oaken1's Avatar
oaken1
since you need the ac upgrade I would go ahead and do that first....sounds like you are set up to move a lot of air but with stock ac it may be choking
Old Sep 14, 2012 | 11:03 AM
Imold's Avatar
Imold
Originally Posted by GunnerFXD
Imold,
I feel kinda retarded that I forgot to mention the acceleration. Off the line she's pretty decent, but if I try to roll on full throttle the bike just about stalls (which is why i was thinking the main jet might just need to sit in some carb cleaner overnight). Right around 60 the throttle response get's real sluggish, and i've got to roll on and off throttle to get some more mph out of her.
I can remember that same problem a long time ago, but not what it was on, or what was done with it, but it does sound like a carb issue. 8541hog's air cleaner suggestion is a good idea too; I recently fixed a riding mower that wouldn't power up by cleaning out the clog of cottonwood tree seeds (white fluff, if you're not familiar with it, like stuffing the filter with cotton) in the ac. Since that old bike had a lot of work done on it, check the jet sizes against stock - with the aftermarket mufflers, the idle jet could be a size up and that's probably good, but if someone thought they needed more gas for all that "power upgrade", might have overdone it on the main jet; for what you have, I'd think the stock jet size might be best. The needle position might have been played with too; that could be a little more difficult to figure out, but there's plenty of carb tuning/setup advice right here in the forum, just do a search on carb tuning.
Old Sep 14, 2012 | 04:45 PM
RoadLord's Avatar
RoadLord
if you have a Mikuni, guy the rebuild kit for it and if you don't have a Mikuni, get one the HSR 42 does wonders for those Evos.
Old Sep 14, 2012 | 08:31 PM
spanky02's Avatar
spanky02
My 96 fxd does a 100 no problem and I need an air cleaner bad.. I still have the stock one and it starves for air sometimes
Old Sep 14, 2012 | 09:31 PM
GraemeR's Avatar
GraemeR
Chit... My 86 FXR is doing 90 in 4th gear so you have a major issue there. Ditch the hyperloser air cleaner and post your gear ratios and carb setup.
chris kuznia
Ironhead
Jul 9, 2015 06:44 PM
mykechambers
Ironhead
Aug 10, 2014 09:53 AM
Norm Webster
Ironhead
11
Oct 14, 2010 02:32 PM
Ultra 99
Jul 5, 2007 11:38 AM
feetsbig
Exhaust System Topics
Feb 24, 2007 01:23 PM
