Is a fuel management system needed with new intake?
Old Sep 18, 2012 | 07:32 AM
fredwalters's Avatar
fredwalters
3rd Gear
Default Is a fuel management system needed with new intake?
Looking at the new K&N "RK" series intake for my 2012 FXDF. K&N says a fuel management system is not needed. Dealer says any intake change requires a FMS.
Old Sep 18, 2012 | 07:44 AM
crimson13's Avatar
crimson13
I think if you just change the intake you will be fine,if you change the exhaust along with the intake i would suggest a tuner
Old Sep 18, 2012 | 09:55 AM
whitewolf001's Avatar
whitewolf001
If your exhaust is a full system or any other performance mods it needs a new tuning map BUT if it has a slip on or stock, you'll be ok. That was directly from K&N tech support. I just did your homework for you.
Old Sep 18, 2012 | 10:33 AM
Loner88's Avatar
Loner88
Hmmm, probably get away with it without tuner, but with the sloppy manufacturing tolerances on Harley's, it's a crap shoot on how well any individual bike will run with intake or exhaust changes and no tuner. For sure it will still run lean and hot, exhibit 'hunting'- ie, the ECU will constantly try to keep the AFR in the desired range when running in closed loop ( many people think this is lean surging, but talking to guys with SERTs and TTSs who collect ECU data with a laptop, it looks like more like the ECU 'hunting' for the preset AFR). Get something to help your bike run at a more comfortable AFR at least, even if your leaving it stock. I am really happy with the Dobeck GEN 3, bike runs good and cool, don't throw codes like it did with ViEDS, ECU is totally unaffected by the fueler, pretty easy install and set-up, and I can take it back to stock with no traces left in the ECU in under 40 minutes, all for a bit more than the ViEDS cost. Of course only works good for a Stage 1 bike, or a very mild mouse cam.
http://www.electronicjetkit.com
Old Sep 18, 2012 | 12:29 PM
nevil's Avatar
nevil
Why install an intake if you're not looking to pick up some extra power? Take some of the above advice and cool your motor down while getting more performance out of it.
Old Sep 18, 2012 | 01:48 PM
Bagger_Vance's Avatar
Bagger_Vance
Another vote for the GEN III. I just sold my XIEDs and picked up a used GEN III for very cheap. It installed in about 30 minutes and after a couple tweaks I can tell a difference over the XIEDs. I liked the XIEDs very much and had no issues but the Gen III gives you tweaking ability over the XIEDs, which is nice.
Old Sep 18, 2012 | 02:30 PM
Ridewva's Avatar
Ridewva
The stock ECU will acclimate to the new intake and K&N dynos claim 6-7 HP gain w/o any other mods. It will be running just as hot (and getting good mpg) as stock.
Will Concho
Dec 7, 2015 06:26 PM
Clark82
May 27, 2015 12:26 AM
Nazkad
Jun 3, 2013 11:57 AM
dmayer
Jan 4, 2011 06:46 PM
ronyd
18
Mar 25, 2009 11:21 AM
