Dash and Speedo
Old Oct 16, 2012 | 12:30 AM
SevieC's Avatar
SevieC
Question Dash and Speedo
I want to relocate my speedo to where my horn cover is. I just dont know what to do with the dash.... If i take it off there is a dent in the tank and if i take just the speedo out there is a big hole cut out where it would have been... would like to have just my ignition there and have it be flush... anyone done this before?
Old Oct 16, 2012 | 10:35 AM
JRK5892's Avatar
JRK5892
you can move it but it is going to leave a very weird look to the top of the tank, and the mounts for the dash are going to stick up and look weird, plus you will see the fuel pump/filter access... you would do better to fiberglass a flush dash cover and then use a sporty speedo on the side, but you will also have to use a tuner to calibrate this to make it work
Old Oct 16, 2012 | 05:53 PM
stewbeezer's Avatar
stewbeezer
Pick-up a Superglide tank, no speedometer hole. Also go with the smaller dyna speedometer.
David Sui
Jan 12, 2018 04:52 AM
skewzme
Nov 10, 2017 10:33 PM
Aussie Madness
Electrical/Lighting/Alarm
May 5, 2017 02:43 PM
alucard9899
Oct 17, 2013 06:05 PM
SURFOR Chop
Sep 14, 2008 07:12 AM
