Sounds from the Forks
Old Oct 22, 2012 | 06:08 AM
blueangel73's Avatar
blueangel73
Default Sounds from the Forks
Lately I have been hearing some creaking from the forks when comeing to a stop or taking off. I don't get the noise when riding, just stopping of launching. When I am sitting still, I lock my front brake and rock the bike back and forth and the creak happens when the legs are compressed completely and then decompressed or fully extended and then returned to natural state. It sounds like walking on the floors of an old home with wood floors and the wood creaks. ANuone have any idea what could be causing this, I have just over 25K on the bike and its a 2010 Street Bob.
Old Oct 22, 2012 | 06:44 AM
dpriest's Avatar
dpriest
Wheel bearings?
Old Oct 22, 2012 | 06:59 AM
mattVA's Avatar
mattVA
My forks made a sort of old mattress noise after installing the intiminators in them. .it quieted down some once the oil lubricated the springs after a few rides. Maybe look for signs of fork oil leaking at the bottom of the tubes.
Old Oct 22, 2012 | 07:47 AM
blueangel73
I can see where your going Priest, but as I said, it makes the noise when I push the forks in and out while holding and locking the front brake, so the wheel isn't moving to rotate the bearings.
Matt, I haven't noticed any oil leaks on my forks, I will have to take a closer look.
I have noticed that the sound happens more often when my detach wind screen in on the bike. But, it does happen when the screen is both on and off.
Old Oct 22, 2012 | 10:41 AM
DCLXVI's Avatar
DCLXVI
Have you had your front wheel off lately? If it was reinstalled without putting a rod in the hole on the axle to get the correct measurement, your forks could be binding up. When done properly you will have a small space between the spacers on the forks. This will allow them to travel without binding.
Old Oct 22, 2012 | 10:56 AM
blueangel73
I had I off back in July, I road about 3k before I started hearing the noise though. What rod are you referring to? I can pull the front wheel off again if needed, I want to move my legs down a little anyways. I just don't know what rod you are referring to.
Old Oct 22, 2012 | 11:23 AM
mattVA's Avatar
mattVA
There's a procedure in the SM where you insert a drill bit or similar tool into the through hole in the axle on the right side of your bike's front wheel. You then torque down the axle nut and it keeps the forks aligned. Without the tool in the hole, the right fork becomes drawn toward the left fork as the axle nut is tightened down which is no bueno. What you end up with is misaligned forks.
Old Oct 22, 2012 | 11:29 AM
DCLXVI's Avatar
DCLXVI
What he said
Old Oct 22, 2012 | 11:31 AM
blueangel73
Thanks for the info, I guess I missed that when I glanced through the service manual. I will have to look it over again and adjust the setup. Thanks again.
Old Oct 22, 2012 | 03:00 PM
nevil's Avatar
nevil
It's a long shot but you still might want to take a look at the front wheel bearings. If they are shot it's possible that they could have worn a groove in the axle which could make a noise even if the bike is not moving.
