diamond cut headlamp
Anybody used one of these on their Dyna?
Is the 2000-2005 Dyna buckets smaller?
Should I get the Harley version and will it fit a 2000 Dyna?
Man I am PO'ed
What have other people used to improve their headlamp on older Dyna (other than LED/HID)
The description...
68297-05
HEADLIGHT REFLECTOR, 5 3/4, DOM
Lighting: Original Equipment on 05-later Harley-DavidsonŽ models, these headlamps feature crystal clear lenses, mirror-finish reflector optics, and replaceable halogen bulb.
Fits: 5-3/4" Domestic. Fits 00-later XL, XR, DynaŽ (except FXDF), FX SoftailŽ, and 05 VRSCB models equipped with 5-3/4" headlamp.00-04 DynaŽ (except FXDWG) models require adapter ring P/N 67883-04.
Ordered a Hella E-Code 5 3/4" round H4 lens (my bike had a sealed beam bulb). Bought H4 bulb.
So, the stock bulb had a "tab" built into the back of the glass that fit into a small slot in the headlight bucket. This Hella unit I purchased had 3 separate tabs welded to the back of the H4 housing. Two of the three tabs was longer than the other two. After looking and measuring a few things, I came up with the idea to cut two slots in the bucket ring so that the two longer tabs fit. Hope that made sense. Works great and much brighter than stock!
MC lens are different than cager lens.Cager lens are designed differently.
Gonna mount it all up next week.
The description...
68297-05
Are you trying to avoid this Harley Davidson Pt#68297-05 and 67883-04?
Werent both these parts standard issue on Sportsters?
