Fitting narrower FXD/C/L rear fender to Fat Bob/Wide Glide question
Old Oct 28, 2012 | 07:31 PM
mattVA's Avatar
mattVA
Default Fitting narrower FXD/C/L rear fender to Fat Bob/Wide Glide question
I'm having trouble picturing where the spacers need to be since I don't have everything in front of me. I'm looking to put a 06+ FXD/C/L rear fender to the wider struts of my Fat Bob. I believe struts are 9" apart and fender is 8 1/8" I.D. I know the front mounting holes use adhesive spacers from Harley that the fender support bracket goes 'through', but for the rear do I want the spacers to be the size of the fender support bracket threaded portions and sit inside the strut? Or do I want the I.D. of the spacers to be large enough to fit over the fender support bracket like the adhesive ones, such that they fit over the bracket, limiting how much the fender can be stretched when the bolts are tightened?
I can try to find a picture.
Thanks,
Matt
Old Oct 28, 2012 | 07:44 PM
Robtarra39's Avatar
Robtarra39
since the fender you want is narrower, you will need spacers that will sit between the struts and fender to close the gap, sounds like you need 3\8 spacers, would only need 4 for the four bolts that support the fender.
mattVA
Nov 8, 2012 06:37 AM
SeaSoldier
Oct 21, 2011 12:11 PM
blueangel73
Jun 15, 2011 02:31 AM
strongwood
Jun 12, 2011 10:18 PM
VA Biker
Jan 28, 2011 06:46 AM
