Floating rotors on cast wheels. Question.
Old Nov 1, 2012 | 08:38 PM
oldbie's Avatar
oldbie
Default Floating rotors on cast wheels. Question.
I bought some OEM cast wheels for my FXDC that came off a Lowrider. Do I have to run the MoCo floating rotor or can I just use the one that came on my spoke wheels? Or...is there a better aftermarket rotor I could/should use? Thanks.
Old Nov 1, 2012 | 08:42 PM
SuperFastGlide's Avatar
SuperFastGlide
the rears are interchangeable, but the fronts are completely different
Old Nov 1, 2012 | 10:08 PM
gartec81's Avatar
gartec81
front is a different rotor. you will have to buy one. make sure its floating though. they tried to sell me the wrong rotor when I did the wheel swap
Old Nov 2, 2012 | 07:49 AM
oldbie's Avatar
oldbie
Thanks. Is there a "better" rotor available in the aftermarket? I plan to upgrade the pads probably to Lyndall gold.
Old Nov 2, 2012 | 08:07 AM
Sharkman73's Avatar
Sharkman73
I've always wondered....why do you have to have a floating rotor on a cast wheel, but not on a spoke wheel? I don't understand why it's needed sometimes, but not others.
Can someone with knowledge of brakes please clear this up? I'm pretty mechanical, but brakes are my area of least knowledge & I don't understand this.
Old Nov 2, 2012 | 10:29 AM
Hogpro's Avatar
Hogpro
Former Sponsor
This all depends on the year of your bike. From my info it looks like 06 was the first year of 11.8" rotors on the front. If you avhe the cast wheels they also have a larger diameter where they bolt on. The spoke rotors have the same bolt pattern diameter but also utilize 11.8" rotors in the front all the way up to current. The rear is still an 11.5" rotor.
40calsg
Jul 5, 2011 08:37 AM
bobby5
Sep 29, 2010 03:18 PM
Travlinman314
Dec 21, 2007 09:10 PM
TheBreeze521
May 4, 2007 01:50 AM
MikeG
Jul 26, 2006 07:19 AM
