Changing from Cast to Laced Wheels, Rotor Question
Old Dec 21, 2007 | 09:36 AM
Travlinman314's Avatar
Travlinman314
Default Changing from Cast to Laced Wheels, Rotor Question
My question concerns the front brake rotor when changing from cast to laced wheels.
I'm a little confused, when I first looked at it, I thought I'd need a new rotor, then did a search in here, and someone mentioned a spacer, figured I'd ask here instead of the Stealership.
What gives, new rotor, spacer? WillI run into the same when start the rear, (rear looks like it is the same fit as the original)
While I'm asking, best place to get rotors? Quality and price?
Thanks
Old Dec 21, 2007 | 09:40 AM
Bob's Avatar
Bob
Default RE: Changing from Cast to Laced Wheels, Rotor Question
I switched my Dyna from spokes to cast wheels.
Everything was the same EXCEPT the front rotor.
Old Dec 21, 2007 | 09:51 AM
skip3406's Avatar
skip3406
The spacers are the same the brake rotor are different.
Old Dec 21, 2007 | 02:41 PM
Travlinman314
Thanks, now to figure out if I want to upgrade both rotors, or just get a front replacement.
I guess I have some time to shop around, at least till spring or so.
Any suggestions?
Old Dec 21, 2007 | 07:09 PM
piniongear's Avatar
piniongear
Well, it sounds like I am the only rider who swapped out cast wheels for laced and had everything just bolt up. Rotor fit perfectly, axle fit, spacer fit. Maybe that's because it is an older model (2003 FXDL)
I had a 19 inch cast front wheel and built a 21 inch laced wheel. It was the easiest thing I ever done......pg
[IMG]local://upfiles/8331/FDE87989C3B74B97A6BF1FE2E6C7AD4C.jpg[/IMG]
[IMG]local://upfiles/8331/0EC7991190554FF6857AB1284EEA7D94.jpg[/IMG]
[IMG]local://upfiles/8331/288ABE5005D44FB0BC982BD0BEF06DB7.jpg[/IMG]
[IMG]local://upfiles/8331/1D9A06F2240D48BCB6E590D1010D48C9.jpg[/IMG]
Old Dec 21, 2007 | 07:15 PM
mmontgomery's Avatar
mmontgomery
A friend of mine has a 21' lace wheel off of a 05 duece, I have a 06 superglide with cast rims, willthe 21'fit my bike anyone know?
Old Dec 21, 2007 | 07:44 PM
piniongear's Avatar
piniongear
Is your front end and his the same width? Or to put it another way, if your axles are the same length it should be an easy swap out. 2005 and 2007 axles should both be 1 inch diameter axles, so check yours as well........pg
Old Dec 21, 2007 | 09:10 PM
dklozik's Avatar
dklozik
Soon as my new wheel gets here, I'll have a stock rotor from my 07 Bob your more than welcome to if you need it. No sense in paying the stealership big $$ for something. Mine has less than 3k miles on it. Let me know if your interested.
Lama
Nov 22, 2019 09:38 AM
chaselee
Feb 10, 2017 07:52 PM
Fresh Deluxe
Aug 15, 2014 08:07 AM
oldbie
Nov 2, 2012 10:29 AM
40calsg
Jul 5, 2011 08:37 AM
