LED Fuel gauge
Old Nov 9, 2012 | 10:05 AM
KKND's Avatar
KKND
Default LED Fuel gauge
I have been thinking to change my fuel cap and gauge on my 07 Dyna WG to the flames collection set. It will compliment all of the Flame theme add-ons I have. I was wondering if replacing the fuel gauge requires some skills or is it as easy as plug and play. When I was cleaning the bike this last weekend the fuel gauge just popped up in my hand and I noticed the harness down there...
Any inputs/suggestions will be appreciated.
thanks.
Old Nov 9, 2012 | 10:13 AM
rs87277's Avatar
rs87277
its very easy, take about 5 min
Old Nov 9, 2012 | 10:36 AM
Gommee's Avatar
Gommee
Devil's Advocate
Pop it out again, unplug it from under the tank, put new one in, plug it in. Easy.
Old Nov 9, 2012 | 10:40 AM
rs87277's Avatar
rs87277
and there is one zip tie you will have to snip
Old Nov 9, 2012 | 11:27 AM
KKND's Avatar
KKND
Thanks guys!! Nice Street Bobs!!!
Old Nov 9, 2012 | 11:32 AM
dobeman21's Avatar
dobeman21
I just had my LED fuel gauge replaced. Mine led fuel gauge on my 07 springer cvo was a bitch- had my local indy dealer do it because I didn't want to screw it up- the attachments for my bike were under the fuel tank, so the fuel tank had to be moved back and the old wire assembly had to be removed and replaced. Yours might be much simpler though.
QUOTE=KKND;10535574]I have been thinking to change my fuel cap and gauge on my 07 Dyna WG to the flames collection set. It will compliment all of the Flame theme add-ons I have. I was wondering if replacing the fuel gauge requires some skills or is it as easy as plug and play. When I was cleaning the bike this last weekend the fuel gauge just popped up in my hand and I noticed the harness down there...
thanks.[/QUOTE]
Old Nov 9, 2012 | 11:37 PM
KKND's Avatar
KKND
Yeah, I guess. The harness looked completely accessible from the void under the gauge so I don't think that I need to remove the tank.
Thanks.
Old Nov 13, 2012 | 07:13 AM
Drifter471's Avatar
Drifter471
Replacing the old gauge with a new LED is simple it most likely won't take you much more than 20 or 30 minutes to change it out. just remember that when you take the old one out if you can't get the wires out of the plug don't sweat it just take wire cutters and leave enough wires so you can re-use it if ever you decide to. Then slide the new harness down the tube and follow the instructions on how to put the new plug on the end of the harness.
Old Nov 13, 2012 | 01:09 PM
markeejay's Avatar
markeejay
+1 easy mod - 5-10 mins max
Old Nov 13, 2012 | 01:42 PM
LBCutta's Avatar
LBCutta
Very easy took me all of 5 mins to install. Also gives it a cleaner look.
