Docking kit and solo rack
Old Nov 17, 2012 | 04:01 PM
Bibber48's Avatar
Bibber48
Default Docking kit and solo rack
I have a 2010 Street Bob and want to use the detachable solo rack on it. I have the docking hardware installed and the turn signals relocated as per the instructions. When I try to install the rack it is too wide for the docking hardware mounts. There is about 3/4 inch difference between the rack and the groove the rack is supposed to slide into. Can someone post pics of the docking hardware mounts installed on their Street Bob. The rack P/N is 53511-06 if that helps. Could someone measure the width of the front mount points on the rack? Thanks
Old Nov 17, 2012 | 08:24 PM
Bibber48's Avatar
Bibber48
No one has any idea?
Old Nov 18, 2012 | 06:48 AM
Harley Tim's Avatar
Harley Tim
I have an idea however, my photobucket account has seemed to "crapped the bed" so, I have no pics to show you.
With the HD docking station, there are spacers, washers and longer bolts to ad as needed to adjust the docking points to the correct width. you could do the same thing with a trip to Lowes, or Home Depot.
I normally run Solo with a QD rack over the fender. I can, however, Remove the solo and rack and put on the sissy bar with pad and luggage rack and, a 2-up seat in about 2 min. (to take Wifey along.)
Works for me.
Best wishes....Tim(HT)
Old Nov 18, 2012 | 06:58 AM
MJR28's Avatar
MJR28
I live in Australia but have a Fatbob in CA. I bought the luggage rack etc on my way to Sturgis this year and had the same problem. I was fitting it at the dealership and I thought I had to get longer bolts but one of the guys came out and pointed out I had something setup wrong. Can't remember what though. It might be worth going past the dealer if that's convenient
Old Nov 18, 2012 | 07:58 AM
DCWilcox61's Avatar
DCWilcox61
I have a 2012 SB with the same rack. I find that i have to 'flex' it just a bit to get it to line up, but 3/4 inch seems like alot. I don't know if you may have installed the brackets with the spacers out of order or not, but I've taken some pics that may help. I'll post them as soon as I can figure that out.
Old Nov 18, 2012 | 08:25 AM
DCWilcox61's Avatar
DCWilcox61
Here are a couple of pix. Maybe they will help.
Old Nov 18, 2012 | 08:35 AM
Bibber48's Avatar
Bibber48
Thanks for the replies and pics. I had the dealer install the docking hardware and they left out some spacers. I am taking it back on Monday and they are fixing it. The spacers should get everything to line up. Again thanks.
Cornhusker
Touring Parts
May 15, 2020 01:32 AM
davey1955
Aug 22, 2018 10:52 PM
DBLXX
Jan 31, 2014 08:35 AM
Reg66
Jul 4, 2011 01:08 PM
hdonly4me
Feb 16, 2010 07:49 PM
