universal chrome mini floor boards
Old Nov 23, 2012 | 07:12 PM
vtchefmike29's Avatar
vtchefmike29
Default universal chrome mini floor boards
I just got and installed the universal mini floor boards from Jp cycle i cant up load a pic but they were $49. I have a 2012 fxdc. I find that after installation they are tilted forward not exactly straight across anyone got a pic of uni versal mini floor boards installed on a fxdc
Old Nov 23, 2012 | 07:58 PM
DOMAPOI's Avatar
DOMAPOI
Old Nov 23, 2012 | 08:02 PM
XKnight's Avatar
XKnight
I have a set of HD mini floorboards and the angle/tilt is adjustable. Should be in the directions if there is a way to adjust your angle. On mine, you just pull out the bolt holding the floorboard and then turn the board as needed to whatever angle/tilt is most comfortable and then re-tighten the bolt.
Old Nov 23, 2012 | 08:13 PM
vtchefmike29
Thanks they are adjustable 2 position one being
Angled slightly down the other upthe up position
I'd to hard to access the brake and shifter with mid controls
The slanted down is ok I believe they are slanted slightly down for brake and shifter clearance
emperor wurm
May 9, 2017 09:52 AM
ecir40
Aug 7, 2015 11:48 AM
Bodacious MC
May 13, 2015 03:03 AM
davidwideglide06
Jun 27, 2010 08:17 AM
Mike Horrell
Jan 19, 2010 08:27 PM
