Mx Tbars with standard cables
Old Nov 28, 2012 | 12:03 PM
Cascade's Avatar
Cascade
Originally Posted by El Rey
My 14" WC MX T bars have a 14" riser with the actual bar being the other 2"
Then you probably have the 16"
Old Nov 28, 2012 | 12:34 PM
desertrat702's Avatar
desertrat702
The connectors on the bikes with hdcan are much smaller. There are less wires and you dont have to take the pins out of the connectors to get the harness through.
Old Nov 28, 2012 | 12:58 PM
Good_Apollo's Avatar
Good_Apollo
Good to know! Thanks
Old Nov 28, 2012 | 01:51 PM
USMCBattles's Avatar
USMCBattles
i got 14s they work fine
Old Nov 28, 2012 | 02:45 PM
Psi23's Avatar
Psi23
The connectors don't need to be un mated from the plug because they reduced size,just unplug and re run. I used two 5mm bolts attached to a string and guitar string to make the bend, then just pulled with needle nose from the bottom hole, removed guitar string tied connectors to the regular string end and pulled it on through. 4 hands make it easier so have someone there.
Old Nov 28, 2012 | 05:17 PM
emerican19's Avatar
emerican19
That would have been nice...
Old Sep 18, 2013 | 07:57 PM
partycrasher's Avatar
partycrasher
A bit confused..... Mx bars say fit upto 2012-- will the 10's or 12's fit on a 2013 street bob ? What changes are required? Sorry for the newbie question
Scooby1426
Audio Systems
Mar 11, 2018 06:29 PM
camoglide
Audio Systems
Mar 30, 2017 04:54 AM
dixieoutdoors
Jan 22, 2015 06:32 AM
HarkinsBG
Apr 9, 2013 12:21 PM
Scheers44
Feb 21, 2011 07:21 AM
