Stupid question from Harley Noob!
Old Dec 5, 2012 | 09:43 PM
Psi23's Avatar
Psi23
oh and the P/N is just the part number for your ECM and BCM it comes up at the end of the codes.
Old Dec 5, 2012 | 09:44 PM
Alamor's Avatar
Alamor
Bcm=62116 & then it says end then reads out Pn 69992-12
Speedo=u0141 then says end and then reads out Pn 67096-12
The ECM says none and has a N
Old Dec 5, 2012 | 10:00 PM
Psi23's Avatar
Psi23
Does your bike have different that stock bars?
Old Dec 5, 2012 | 10:02 PM
Psi23's Avatar
Psi23
also there should have been a letter in front of the 62116 code what was it
Old Dec 5, 2012 | 10:03 PM
Alamor's Avatar
Alamor
No, the only thing that aren't stock is the tail light is the smoke LED different rear shocks, and some black trim pieces.
Old Dec 5, 2012 | 10:08 PM
Alamor's Avatar
Alamor
Oops it's not 62116 it's actually b2166
Sorry!
And the bike did have black triple trees installed but not handle bars
Old Dec 5, 2012 | 10:14 PM
Psi23's Avatar
Psi23
find that letter under the BCM, the u0141 means that the LHCM is losing communication, there should be a letter before the first code. The good news is most of the time these are just communication errors from the BCM, I think the 62116 was ignition but let me know the number again so I can double check.
Old Dec 5, 2012 | 10:16 PM
Psi23's Avatar
Psi23
Okay so sorry to trouble shoot you some more
does your bike have running lights? next thing I want you to do it when you get to the u0141 Hold the button down till it says clear, then run the bike for a few minutes turn it off and check if that code comes back. Your B2166 code means you have a short to your running lights or they have been removed.
Alamor's Avatar
Alamor
The bcm code isn't 62116 it's B2116. I thought the b was a 6 at first.
Old Dec 5, 2012 | 10:22 PM
Psi23's Avatar
Psi23
wait my fault the b2116 means you have a fuel pump issue. For sure it is b2116 not b2166, also clear them both and start and run see if they shoot back up.
