Rough Stage I
Old Feb 2, 2007 | 01:08 PM
MrZorba's Avatar
MrZorba
6th Gear
Default Rough Stage I
Ok here is the problem (or mayby not a problem)
06 FXDCI, at first service by dealer installed the HD intake Stage I and the HD slip on mufflers p/n80366-99 and HD dowload to match.
The sound is plenty for me, and there is noticeable difference in power ....but I now notice more vibration when decelerating and not very smooth at lower speeds and RPM as compared to stock. What gives ? I was expecting a smoother running set up. Stock was better.
Comments please.
Old Feb 2, 2007 | 01:56 PM
jca_54's Avatar
jca_54
Default RE: Rough Stage I
Is the bike popping / backfiring on deceleration or is it actually shaking / vibrating?
Old Feb 2, 2007 | 02:53 PM
MrZorba's Avatar
MrZorba
6th Gear
I would say shaking and vibrating more than stock.
Old Feb 2, 2007 | 03:05 PM
Matrix's Avatar
Matrix
I have the same set up as you but with Rush exhaust. I didn't noticce that at all. Are you sure it isn't a motor mount problem.
Old Feb 2, 2007 | 06:35 PM
soup48's Avatar
soup48
Go and check to see if you have the 8 degree or 25 degree injectors. Ifd you have the 8 degree that might be your problem.
Old Feb 3, 2007 | 12:25 AM
MrZorba's Avatar
MrZorba
6th Gear
OK new at this, Nothing has been changed... how can I tell which injectors are installed ?
Would chnging the intake and slip on effect this ?
I read here about PCIII and CERTs.... could that be an issue ?
Thanks.
Old Feb 3, 2007 | 12:28 AM
MrZorba's Avatar
MrZorba
6th Gear
Unless the dealer mech did something to engine mounts i dont see how they have gone bad one day to the next.
I assume you did the dowload for your stage I and Rush exhaust ?
Weeboy1
Apr 16, 2015 04:11 PM
GEORGEW
Jul 11, 2009 02:37 PM
CK Bobber
Jun 20, 2008 06:45 PM
Rick05FLH
Apr 22, 2007 03:20 PM
intruder400ex
Oct 25, 2005 11:02 AM
