Rear Shock Help!!!
Old Dec 8, 2012 | 08:48 PM
jmartin99's Avatar
jmartin99
Default Rear Shock Help!!!
I have a 2006 Dyna Wide Glide. I am a big guy (300+) and when my wife rides with me, I have problems with bottoming out. I have heard the stock HD shocks are not that great so I want opinions on which shocks to get.
Thanks!
Jeff
Old Dec 8, 2012 | 09:13 PM
sonnydaze's Avatar
sonnydaze
have you turned shocks to heaviest setting ? how much does your wife weight ?
Old Dec 8, 2012 | 10:00 PM
maddghost's Avatar
maddghost
Obviously your going to go with heavy duty shocks, but IMO give howard at motorcycle metal a call he will fabricate exactly what you need.
Old Dec 8, 2012 | 11:38 PM
beagle01's Avatar
beagle01
go for shocks with a longer travel. Maybe around 13". You can also fit some ultra air shocks on and that should sort your issues out. I'm sure there are plenty of take offs around.
Old Dec 11, 2012 | 07:14 PM
clang's Avatar
clang
If you do not want to spend a lot of money, find a pair of bagger take-off air shocks. They are longer (12.8") and are easy to adjust pressure if you buy the air pump designed for air shocks.
I put them on my Fat Bob:
Take off shocks cost me $60, I picked up 2 air valves for $5-10 (use pipe dope, not teflon tape), and the pump cost $30 off *bay. Improved the ride dramatically (I am a big guy too and ride 2 up).
A Pair of HD 13" Progressive 440s would probably work just as well, but you'll be out another $300-$400.
Corn Born
2014-2024 Touring Models
May 4, 2014 04:44 PM
slowrollin
Mar 26, 2014 11:59 PM
Johneb48
Dec 18, 2012 06:47 AM
fireman36
Jun 1, 2010 03:53 AM
roofer
Oct 16, 2009 09:28 AM
