sissy bar
Old Dec 13, 2012 | 03:57 PM
wt street bob's Avatar
wt street bob
Default sissy bar
Hello. I was wondering if a sissy bar off a 2002 wide glide will fit a 2012 streetbob? Thanks in advance
Old Dec 13, 2012 | 04:47 PM
HDCustomFabrication's Avatar
HDCustomFabrication
In a word, No, pre 06 rear ends are narrower than newer bikes. The 02's were 7.5" and newer ones are 8.5 to 11.
We can custom make any design sissy bar if you are looking for a specific look.
Old Dec 13, 2012 | 06:31 PM
wt street bob
kinda figured. thanks. what kind of designs do you have? i want to keep a bobber look to the bike
Old Dec 13, 2012 | 06:49 PM
HDCustomFabrication
From very simple round stock bent, to something like this: Or anything else you can think of. These design are both under 100 for just the bars with powder coat, no pads or emblems.
Old Dec 13, 2012 | 07:46 PM
stbobau13's Avatar
stbobau13
how do those attach?
Old Dec 13, 2012 | 08:03 PM
HDCustomFabrication
Those particular bars bolt on just like stock Harley. I tap them for 1/4x28 bolts. Most bars unless you request different I use 9/16 square stock or 1/2 round stock.
If you have a welded on bar now you can send me your current setup and I will remove it and build you a new one in it's place.
Really not many if any limitations.
Old Dec 14, 2012 | 12:55 AM
Jacoblb's Avatar
Jacoblb
Would I need the brackets to mount those to the fender struts?
Old Dec 14, 2012 | 01:10 AM
HDCustomFabrication
We are working on a new detachable bracket system but it is not available yet so for now yes you would need the stock type brackets to mount these.
Old Dec 14, 2012 | 04:01 PM
Odis01's Avatar
Odis01
Harley detachable work?
Jim
Old Dec 14, 2012 | 04:04 PM
HDCustomFabrication
Jim
Yes, as long as it has the standard 1-1/4" bolt hole spacing for the sissy bar attachment, if it has anything else I just need to know so I may accommodate.
I use Harley detachables on mine since I don't like having them on the bike all the time.
