changing front isolator
Old Dec 17, 2012 | 03:38 PM
DJY's Avatar
DJY
Default changing front isolator
Tried to research and really couldnt find info on why you would need to shim this. Should I be alright just to swap old for new without shims? Thanks. Edit: Shes an 09 FXD
Old Dec 17, 2012 | 07:14 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Seems the shimming was to correct an excessive vibration issue or a bad isolator installation from the factory.
Old Dec 17, 2012 | 09:10 PM
nevil's Avatar
nevil
You only need to shim it if there's daylight between the mount and the frame when you put the mount in place. If there's space that means when you tighten down the mount you will be stretching it and it won't last too long and won't be working its best.
There's a few good threads here about motor mounts, keep looking.
Old Dec 18, 2012 | 06:03 AM
AFMM3's Avatar
AFMM3
I did the shim and it helped a bit, but I will do the procedure in the service bulletin next spring. https://www.box.com/s/42af95077c683c50e461 as I believe it is more appropriate.
Old Dec 18, 2012 | 12:44 PM
DutchBob's Avatar
DutchBob
This worked best for me. When I changed my isolator I still had a little gap.
After the alignment procedure the gap was gone.
apetterez
Apr 1, 2015 06:45 AM
Streetrunner
Sep 4, 2013 11:58 AM
McMurphy
Jul 24, 2013 08:23 AM
Born2Glide
Oct 21, 2010 03:37 PM
Streetrunner
Apr 10, 2009 09:10 PM
