New DK Profile A/C
Old Dec 19, 2012 | 11:12 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by ZeroFiveFour
Thanks. I am just considering the DK ac Cover however and not the complete set up. I was wondering if the DK cover would be deep enough to work with the SE round air cleaner. Looks like it might.
This is a link to the cover I am considering. I am fairly certain it is the cover from your set up.
http://www.dkcustomproducts.com/Chro...?categoryId=-1
Cheers,
Tom
Yes, it will fit the SE round air cleaner, and the Ness Big Sucker, and the Fuel Moto Stage 1 perfectly.
It will not be as low profile, because the actual air cleaner behind the cover sticks out more than the DK Set up. However, it will give you more leg room than the football cover.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Dec 20, 2012 | 08:58 AM
Reindeer's Avatar
Reindeer
Looks good. That exact setup is on my winter mods list.
I'm a little confused by the 'outlaw breather' bolts, however. Are they just open to the atmosphere? Is water intrusion an issue? I'm guessing DK has this figured out, but I'm not sure I quite understand what the breather system's all about.
Old Dec 20, 2012 | 09:31 AM
crimson13's Avatar
crimson13
The outlaw breather bolts from DK vent to the atmosphere , I did not have a problem with water intrusion.
Old Dec 20, 2012 | 10:01 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
When riding water intrusion is not an issue, even in sustained heaving rain.
When washing it is best not to direct a stream of water directly at the bolts, or do what I do, masking tape them off, then you don't need to worry about it.
Inside the bolt is a channel and a small reservoir, there are there is a mesh screen, then some foam filter material, then an outside mesh screen.
The reason to vent the hot oily air into the atmosphere is that your bike likes cool dry air in the intake. It will run better and have less carbon build up.
With all our Outlaw air cleaners there is also the option of the traditional hose and filter breather system, which accomplishes the same benefit as the breather bolts.
http://www.dkcustomproducts.com/All-...ngines_c76.htm
Old Dec 20, 2012 | 10:51 AM
Reindeer's Avatar
Reindeer
Kinda figured something like that. Thanks for the response and the reassurance.
Rambler81
Touring Parts
Oct 18, 2016 11:22 AM
Rick Tessandori
Sep 5, 2016 11:01 PM
Berick
Apr 8, 2015 10:29 PM
schumacher
Mar 29, 2009 06:03 PM
schumacher
Mar 29, 2009 03:17 PM
