Front fork rattle?
Old Dec 30, 2012 | 06:13 PM
Cruzn34's Avatar
Cruzn34
From: American by Birth, SOUTHERN by the Grace of GOD!
Default Front fork rattle?
Got a 2004 dyna that seems to have a definite clunk while going across a big bump and is very noticeable when you grab the front break hard and the front end dives forward! Harley shop tech says its normal, but something sounding like its very loose are about to fall apart is not normal! Checked the sterling stem bearings and bearings are good. Also checked bearings in front axle with bearings also being in great shape. Sound is coming higher up in the forks and can be felt in the handle bars when it happens. Still feels like something is either loose or has a lot of slack in it!
STUMPED and need some advice here!
Old Dec 30, 2012 | 06:20 PM
Robbie13's Avatar
Robbie13
LOSER
https://www.hdforums.com/forum/dyna-...-m-1215-a.html
Old Dec 30, 2012 | 07:20 PM
gguerra988's Avatar
gguerra988
6th Gear
Check your gas tank and your motor mounts, I had a similar problem and found that my tank bolts was loose.
Old Dec 30, 2012 | 07:29 PM
Cruzn34's Avatar
Cruzn34
I'll check that tomorrow! Thanks!
Old Dec 30, 2012 | 07:46 PM
fishnpo's Avatar
fishnpo
My 04 FXD does the same thing. Some thing about the stem bolt, I don't really understand. One of the things I'm trying to learn about now.
Old Dec 30, 2012 | 08:08 PM
rooti's Avatar
rooti
You said you checked your stem bearings, but did you check the fall away to see if the were adjusted properly...that's usually the cause of what your describing.
It's also about time to change out your fork oil anyways. Check your preload and drop some ricor intimidators in it while you have it apart
Check out this service bulletin:
here tis http://apicdn.viglink.com/api/click?format=go&key=053cd205425636588175bcd76e69cf f2&loc=http%3A%2F%2Fwww.hdforums.com%2Fforum%2Fdyn a-glide-models%2F358330-service-bulletin-m-1215-a.html&out=http%3A%2F%2Fwww.box.net%2Fshared%2Fnad iwe08ok&ref=http%3A%2F%2Fwww.hdforums.com%2Fforum% 2Fdyna-glide-models-9%2F
__________________
Old Dec 30, 2012 | 08:54 PM
Cruzn34's Avatar
Cruzn34
Found the thread and located the bulletins and I will be on my way to the dealership tomorrow to get the part! Thanks!
Old Dec 31, 2012 | 01:12 PM
Cruzn34's Avatar
Cruzn34
All of you here are the Greatest! I had a problem, went here to ask for advice, got the best advice. And fixed my problem!! The steering nut was loose and the old thin washer was the problem! Installed the new washer, steering nut, torqued it down, went for a ride, and bike is like a new bike! Ride is perfect and no complaints! Part cost $1.70! Cheaper than having the stealer fix it!
Thanks gang!!
Old Dec 31, 2012 | 01:27 PM
Robbie13's Avatar
Robbie13
LOSER
Glad you got it worked out!
13RoadKing
Mar 9, 2017 10:35 PM
Turret_plug
Sep 1, 2012 03:54 PM
jake.h
Jun 16, 2010 05:14 PM
smithmx47
Oct 25, 2009 07:36 AM
Mississippi Bagger
Jan 24, 2008 03:30 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
